First post, by Legend789
I'm a returning member = P So Hi again.
Anyways, I was trying to get SkyRealms of Jorune: Alien Logic to install and I <em>know</em> that it will run even with this, but I wanna make sure that it will work 100%.
Install says that I need to set "files=60". And I read that files= is an old config.sys variable statement that deteminds how many files DOS can run at the same time. DOSBox can do 50 files at a time, Alien Logic requires 60.
Is there anyway to set that up? I checked the conf file, the D-Fend prof file, and did a general search on this website.
Please anybody help me if you can, and thank you in advanced 😄
