Help for a newbie
First post, by gricla
Hi all,
I am trying to use one old DOS assembler/linker/locator for 8085 processor.
To call the locater I use the following string inside a batch file:
"LOD85 xpar.cmd end.abs"
where "xpar.cmd" file is a text file with specific command for LOD85 linker/locator
What I see is that LOD85 start under dosbox but the commands inside xpar.cmd are not executed.
Any suggestion?
Thanks
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
Does it work outside the batch file? Any error message?
Reply 2 of 2, by gricla
Hi,
if I run rthe following string from batch file:
"lod85.EXE @ALPHA,BETA34,GAMMA34"
where ALPHA is the command file BETA and GAMMA are output file (abs and map)
The result is I obtain to run the loader (the header is printed on screen) but the error message is:
" ****LOAD NOT COMPLETE"
and the abs file is empty, and the MAP file say:
* LOAD object files
LOAD EVDINIT,EVDSELEC,EVDTIMER,EVDRS232,EVDCRC,EVDFLAG,EVDRAM
UNEXPECTED END OF MODULE
**LOAD NOT COMPLETED
The structure of the ALPHA.CMD file is:
*Command_file: ALPHA.CMD
* Include nel file EVPD.ABS:
* - local Symbol table
* Include nel file EVPD.MAP:
* - local symbol Table
* - eXternal symbol table
* - cross Reference table
LIST S,T,X,R
* Define segment start addres
ORDER C,D,M,S,X
CODE 0000H
DATA 1000H
EXTRA 8000H
MEMORY 2000H
* Load OBJ files
LOAD EVPDDISP,EVDCONF,EVDEPROM,EVDWCDOG,EVDVFILT,EVDUTIL,EVDMESS
* End del command_file EVPD.CMD
END
If use the same command string from the command line, the result is exactly the same.
