First post, by Eric Weir
- Newbie
I am currently running DOSbox 0.65 under Ubuntu 7.4. Following instructions on the Debian website I attempted to add a respository to my sources list and upgrade to 0.72. Specifically, Using Software Sources I entered:
deb http://debian.oregonstate.edu/debian sid main
After which Software Sources notified me that my files were ot of date. After the files were downloaded I got the following error messages:
First,
W: GPG error: http://debian.oregonstate.edu sid Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A70DAF536070D3A1
And then,
E: Dynamic MMap ran out of roomE: Error occurred while processing qt4-dev-tools (NewVersion1)E: Problem with MergeList var/lib/apt/lists/debian.oregonstate.edu_debian_dists_sid_main_binary-i386_PackagesE: The package lists or status file could not be parsed or opened.E: _cache->open() failed, please report.
Subsequently Adept notified me that an upgrade was available, but then reported that the database could not be opened. It recommended that I try running apt-setup and apt-get update, which I did with the following result.
eric@eric-linux:~$ apt-setupbash: apt-setup: command not founderic@eric-linux:~$apt-get updatebash: aapt-get: command not founderic@eric-linux:~$
So, three questions: [1] How do I add the key? [2] Is the second error related to the first, and what do I do about it? [3] Why were the apt commands not found?
Absolute beginner, so thanks for any help.
Eric Weir
Xubuntu 8.04
