Reply 26380 of 52780, by Baoran
Bought this vlb video card from Finnish auction site and it arrived today. I only had one vlb video card before that a tseng labs et4000/w32p and it is in my 486 33Mhz pc. Now I have a spare in case the one in there fails. Both of my cards have 2mb memory.
1.89 MiB
I wonder how compatibility and performance of the new card compares to the old tseng labs card.
Reply 26381 of 52780, by yawetaG
cyclone3d wrote:
doaks80 wrote:
jaZz_KCS wrote:
- PLG100-VH vocal harmony
- PLG100-DX DX7 FM synthesis
Any games make use of/enhanced by these?
Nope, totally for music production... I wonder if you can re-route midi to them though. That would be pretty trippy to have DX7 play your MIDI.
I have an SY-99 keyboard (FM + Synth). I haven't tried using it for MIDI in games though.
You can't do that. The MIDI specs on such FM synths are completely different than on GM modules. First and foremost, they are not standardised like GM, but also there can be major differences between the MIDI specs of different FM synths. Furthermore, the PLG100-DX has some voice loading issues - it has to happen through a specific software editor and the method Yamaha chose is pretty bone-headed.
On the other hand, if you were to stuff the PLG-100VH in a XG module such as the MU-128, MU-1000, or MU-2000, you might be able to use the effects on GM or XG music.
Reply 26382 of 52780, by dionb
In pure DOS VGA, I'd expect the ET4000 to win performance, the S3 928 in SVGA compatibility. Probably the 928 would win in Windows performance, as for SVGA DOS performance... no idea...
Both are very decent cards though 😀
Reply 26383 of 52780, by kixs
S3 928 is older than ET4000/32p and it's slower both in DOS and Windows. But it's a good card none the less.
Reply 26384 of 52780, by liqmat
You know, Trident is always getting a bad wrap and most of the time deservedly so, but this little guy actually benched exactly the same as a Diamond Stealth 24 ISA card of mine and beat out quite a few of my other ISA VGA cards. Not bad from a Trident card.
925.36 KiB
Reply 26385 of 52780, by schlang
how about Oak cards? 😁
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 26386 of 52780, by liqmat
Oak cards are great for a few types of games. They work great with point and click adventures for one. It really depends on what you are using them for. This particular model I benched came fairly close to that Diamond Stealth 24 ISA card. Not too shabby either.
782.55 KiB
Reply 26387 of 52780, by bjwil1991
That OAK card looks pretty good. How much video memory does it have on there?
Reply 26390 of 52780, by Intel486dx33
That was my first ISA graphics card "Oak tech"
I later upgraded to a SVGA card I think it was a VLB Cirrus Logic or Trident. S3 are good too.
I would go with a SVGA card. Graphics are allot better than VGA.
Reply 26391 of 52780, by liqmat
badmojo wrote:
There are some nice ISA era Trident based cards for sure, never seen a good VLB Trdient though.
Funny you should mention that. I have two Cirrus Logic chip based VLB cards and a Trident chip based VLB card and both the Cirrus Logic VLB cards definitely outperform the Trident card, but not substantially.
881.23 KiB
1.04 MiB
It all depends on what type of system you are trying to build. If it's a 386 system, like I am building shortly, I want to bench all my ISA cards. Probably that Oak card I showed above since most games on a 386 wont need more than that. If it's an early Pentium build, sure, SVGA might fit into that. SVGA really didn't get good performance, in my experience, until the mid 90s right before the 3D cards started coming to market. I remember MechWarrior 2 just barely getting by in SVGA on my Pentium 100.
Reply 26392 of 52780, by bjwil1991
Ah, Cirrus Logic CL-GD5428. My Packard Bell Pack-Mate 28 Plus has that integrated (VLB) onto the motherboard. Planning on upgrading the video memory to 2MB using the ZIP memory.
Reply 26393 of 52780, by tayyare
The only Oak card that I have (original from my first PC) is actually a lovely card, if not the fastest around (definitely not, even any Trident can run loops around around it).
It has both digital/TTL (9 pin) and analog/VGA (15 pin) outputs, switches to put it in hardware emulation modes like MDA/CGA/EGA, and it works both in 16 and 8 bit ISA slots.
It's the most versatile card I ever had.
700.12 KiB
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 26394 of 52780, by liqmat
tayyare wrote:
The only Oak card that I have (original from my first PC) is actually a lovely card, if not the fastest around (definitely not, […]
The attachment a10d2e14482eac124b8a83fcc99b.jpg is no longer available
I think I have an earlier version of your card. Not familiar with the 9-pin digital VGA output personally.
919.22 KiB
Reply 26395 of 52780, by Der_Richter
Bought another AS/400 system for cheap. I really don’t have the space for another one, but the company that owned it was going to migrate and trash it. Can’t have any of that happening to such a gorgeous setup. So I bought it for about 5 usd 😀 Now to figure out where to put it...
Preserver, refurbisher, collector. In that order.
Reply 26396 of 52780, by tayyare
9 pin output is not VGA, it's for EGA/CGA/MDA monitors
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 26398 of 52780, by yawetaG
liqmat wrote:
Funny you should mention that. I have two Cirrus Logic chip based VLB cards and a Trident chip based VLB card and both the Cirru […]
The Trident TGUI9400 CXi is good, the driver also provides GUI acceleration in Windows 3.11 IIRC.
