Reply 27500 of 52813, by liqmat
dkarguth wrote:
Friend of father gave me this NEC MultiSync JC-1401P3A monitor. It is one of the first VGA capable monitors, and was ranked amon […]
Friend of father gave me this NEC MultiSync JC-1401P3A monitor. It is one of the first VGA capable monitors, and was ranked among the best when it was introduced in 1986.
Wow. VGA in 1986. That was expensive. My family bought an Amiga 1000 that year.
Reply 27501 of 52813, by appiah4
Hey, the C1084 was no slouch!
Reply 27502 of 52813, by dkarguth
Is the 1084 capable of displaying VGA? I was under the impression that VGA went out of its frequency range. I love the 1084, it's possibly my favorite monitor of all time. Composite, Luma/Chroma, CGA, and RGB all in the same monitor!
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 27503 of 52813, by appiah4
Eh, it's a different beast altogether and I'm sure someone more knowledgeable than me will answer but technically it's capable of only up to 640x256 progressive so it can't do all VGA modes (640x480x16 for example) progressive, although 640x200x16 and below, including 320x200x256 is possible (Although for an Amiga you would need AGA for that). It can also do 640x512 interlaced but that's not really comparable to a real 640x480 progressive signal.
There's also that it's a 15KHz monitor so it does not natively accept VGA signal, just 15KHz RGB.
It's definitely a better monitor than the NEC though 😎
Reply 27504 of 52813, by dkarguth
Them's fightin' words! 🤣
The NEC is actually a more versitile PC monitor for IBM compatibles. It does MDA, CGA, EGA, PGA, and analog video all the way up to 800x560. As much as I love my 1084, the NEC is now my go to monitor for my 286 setup. The 1084 belongs with my Commodore 128d. I have an Amiga 2000HD, but it is paired with a Nanao Flexscan F560i. Another amazing monitor, possibly the best picture quality of any CRT I've ever seen.
Reply 27505 of 52813, by arncht
Mar 86 - $800
Overdoze of the demoscene
Reply 27506 of 52813, by Cyrix200+
Burrito78 wrote:
Sound Blaster 1.5 - CT-1320 C - Boxed New […]
Sound Blaster 2.0 - CT1350B - Boxed
Sound Blaster Pro - CT1330A - "Like New"
Good heavens! Nice stuff!
1982 to 2001
Reply 27507 of 52813, by Cyrix200+
I got this for a few bucks. Does anybody have an idea of brand/type? Looks like a pretty early Slot A board, with onboard LAN (and sound). No markings on the back side. Haven't turned it on yet, so no further info.
EDIT: nevermind, it's an ECS K7ASA: http://www.motherboard.cz/mb/ecs/K7ASA.htm
1982 to 2001
Reply 27508 of 52813, by wiretap
Just over 10 years old now, so I figured every time I see a decent deal on "newer" stuff I'll pick it up because the price is bound to get ridiculous in the future. MSI P7N Diamond (came with a Q6700) for $30.
My Github
Circuit Board Repair Manuals
Reply 27510 of 52813, by Intel486dx33
Lian Li case ( I love these aluminum cases ).
Gravis gamepad DOS PC controller.
    144.06 KiB
    498.8 KiB
    257.31 KiB
    150.53 KiB
Reply 27512 of 52813, by Vynix
Ha ! I have a very similar case, albeit mine has only 2 3½ slots and not 4
By the way you can fit full-height 5¼ drives in that case..
Reply 27514 of 52813, by Vynix
Intel486dx33 wrote:
Yeah, these cases are a little big , but it beats working in those cheap cases.
They beat cheap cases on all sides :p
The one I have (IIRC the model is PC-7Plus black), is probably the sturdiest and heaviest case I've ever owned.
Reply 27516 of 52813, by Daniël Oosterhuis
While its manufacturing date of August 2007 makes it kind-of not really retro, the underlying hardware definitely fits the bill, I think.
At my favorite thrift, they often sell old HP Thin Clients, varying between mostly VIA and Transmeta based models, but today I lucked into one I had hoped would show up there, an HP T5720, with an AMD Socket A Geode NX 1500 1GHz CPU. Essentially it's a low end Athlon XP that's been made more power efficient to run with passive cooling inside this low power machine. With its PCI slot, it could be very interesting for retro PC usage.
I think PhilsComputerLab has videos on this very model. Bonus CPU photo from when I took it apart and repasted it, too 😎
Images removed for copyright reasons.
Reply 27517 of 52813, by liqmat
Been on the hunt for a high quality 4:3 ratio LCD monitor for my testing area. Finally found one in a local Craigslist listing for $25. It's a heavy monster, but it's in mint condition and absolutely beautiful image quality. Say hello to my new member of the family. An IBM 4945-20X T120 20.1" LCD monitor. Best lunch money I've spent in quite awhile.
943.91 KiB
Reply 27519 of 52813, by Zero_sugar
I've been on the lookout for one for a while. Every time I go to RePC I see dozens of 5:4 screens and a few 1024x768 screens, but never any 1600x1200, 4:3 screens.
