Reply 27920 of 52979, by God Of Gaming
^ nice, bought the same thing recently myself, its rather noisy tho, so I'm not using it right now. Cooler seems identical to asus nvidia 6600 gt, so probably an aftermarket cooler will fit fine
1999 Dream PC project | DirectX 8 PC project | 2003 Dream PC project
Reply 27921 of 52979, by matze79
i toke the fan apart, the fan has a bearing, i just put the bearing a few minutes in oil and build it in again.
Now its ok.
    97.2 KiB
Reply 27922 of 52979, by dionb
respect2759 wrote:
dionb wrote:
respect2759 wrote:
Hello, I am new here, this is my todays finding
Nice little LPX. Watch out with the RAM - you almost certainly need four identical 30p SIMMs in the first bank to be able to boot, not the two in here now.
I dont have more 30p SIMMS only these two. This is my oldest PC I am new in retro field I was only collecting now I want to start with builds. So I have to buy now 4 identical? Here we dont have much retro stuff and ebay shipping fees are too high for me (for a 1euro thing postage is about 10-15) I found the manual online, its a Siemens Nixdorf S26361-D756-v motherboard.
You need 4 identical, so 4 new ones or 2 of same kind as you already have. You should be able to find cheaper options than that - I set my account on a popular auction site to .sk, object location to global and found an option for 4x1MB in DE for EUR 8 with EUR 6 shipping.
Reply 27923 of 52979, by HanJammer
This one is definitely a keeper. Found on local auctions.
286 Suntac motherboard, full size MFM controller, full size VGA, hardcard (unfortunatelly disk won't spin up, I might attempt a repair or replacement).
Also take note of the sticker on the case and behold the ultimate computing power of this machine.
Reply 27927 of 52979, by keropi
oeuvre wrote:
you must make replicas of this sticker
QFT
Reply 27928 of 52979, by cyclone3d
Yes, definitely.
What we need is either a high quality in-focus macro shot of the sticker along with the measurements OR a high quality scan done with a hand scanner.
Or you could lay the cover on a flatbed and scan it that way. 600dpi should be good.
Here is a link to the page that the sticker originally came on:
http://www.cpucollection.se/details.php?image_id=1252
And the pic snagged from said link:
145.13 KiB
I'll clean up the image if we can get a scan of it.
Will the black smudge come off easily? Is it a paper sticker or more of a plasticy sticker?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 27929 of 52979, by HanJammer
Predator99 wrote:
Looking great! Can you send pictures of the VGA and the board?
Is the Hardcard-Drive MFM or IDE?
It's MFM. I can hear the head servo 'knocking' on powerup, but disk won't spin up...
I'm going to dismantle it today and I will take detailed pics of the cards and the motherboard.
Also I just bought (from the same guy) these three PCs... he seems to import these machines from Germany...
First two are Highscreen 286s with what seems as Octek Fox M motherboards. I find interesting that the first one has Winchester/MFM hard drive but it's definitely IDE era PC...
I pretty much hate those Highscreen cases - very poor quality (thin sheet metal, poorly designed) but they seem to hold very decent prices for some reason (I recently sold one for the same price as I bought each of these three PCs).
(pics are not mine).
884.77 KiB
1.07 MiB
878.52 KiB
1009.76 KiB
851.83 KiB
Reply 27930 of 52979, by HanJammer
1006.85 KiB
Reply 27931 of 52979, by brostenen
Finally recieved the breadbin. And I am extremely happy. The image is extremely sharp for a Commodore64, the sound is perfect. The two joysticks are not that good. They are nearly worn out. I got a tapedeck/datasette and with it I got 26 tape's. The only thing about it, are that the case is halfway urine colour. Yet it is the image quality that I am extremely surprised with. If anyone are qurious on to what PCB assy it has, then it is AssyNr: 250407. And it should not be that hard to source, as it is one of the most produced boards. The 250466 are a bit harder to source, yet that should have the absolute best quality of all C64's. That is the first release of the PAL C64 Model C. Anyway.... Not bad for 93 Euro.
Reply 27932 of 52979, by HanJammer
cyclone3d wrote:
Yes, definitely. […]
Yes, definitely.
No problem. I will do that. I will try to make good quality photos first before I attempt stain removal. I want to retrobright this case so I will have to remove the sticker from the case (unless it's a paper one then I will probably let it live and won't do retrobright it).
EDIT: Good news, it's printed on PCV film so it should be no problem cleaning it up and even removing it (I will take pictures before removing in case it's dammage in process).
EDIT 2: Pics of the cards and motherboard. I have another Suntac motherboard almost just like it. It's amazing how clean these 30+ years old card are. Only motherboard needs some dusting.
691.26 KiB
785.05 KiB
720.12 KiB
676.15 KiB
846.82 KiB
Hard drive on this hardcard is Microscience HH 325.
Also this fancy, fabulous sh*t the Video Seven VGA does during POST:
https://youtu.be/5phWUS-pAto
Reply 27933 of 52979, by appiah4
Got this ATX case for $4 because it was on sale at a walk's distance. Not sure what to build in it. It has a Windows 2000 Pro 1-2 CPU COA sticker on it so it must be from the Pentium 3 / Athlon era.
Reply 27934 of 52979, by Predator99
Really cool cards inside! Never seen this VGA. Would be happy if you add your board to my Suntac Thread 😉
Reply 27935 of 52979, by HanJammer
I will :]
It's my sixth or seventh Suntac motherboard too BTW...
Also, a one drink and few prayers to older AT gods later and... HDD spins up...
https://www.youtube.com/watch?v=hr4IZXnQNnQ
Reply 27936 of 52979, by MMaximus
Nice lot you just got here! I also have a few Suntac boards as well. Am I wrong or do you have 70ns 1Mx8 RAM chips on that board? Quite the overkill for a 286/10! 😲
also, nice looking cat on the video 😀
Hard Disk Sounds
Reply 27937 of 52979, by Deksor
Bought this boxed SB 2.0 😁
799.23 KiB
786.09 KiB
Interesting fact : it's localized ! So having one in my tongue is even better 😁. Can't wait to receive it ! It will be my oldest boxed sound card (at the moment it's the AWE64)
Reply 27938 of 52979, by retardware
Highscreen was the brand of the former Vobis computer outlet chain in Germany.
Cheapest stuff of worst quality.
They took what was cheapest at the time and threw that together, and then you had a "highscreen" PC.
MFM HDD in early IDE age is so symptomatic... they took the surpluses that nobody wanted and sold them as "brand".
Also these are dangerous... the thin sheet metal of the cases is sharp like knives.
If you want quality, be careful, it is rare to find in such boxes.
Reply 27939 of 52979, by Deksor
This guy seems to really like them though https://www.youtube.com/watch?v=BoD0KNEdXnY He did a really good job at restoring his computers ^^
I have a highscreen computer (pentium era) and even though I broke the motherboard years ago, I don't think they're that bad, (or at least they weren't too bad by that time).
