Reply 29040 of 52803, by brostenen
- l33t++
wrote:Yes i know that, this is the only way to get the 1meg chipram over the trap door. It's kind of a conversion into an A500+.
More or less. Yes. Though you need a true 8a.1 or 8a board and have the onboard mem upgraded to 1mb, then you need a kickrom 2.x and finally make sure that the chipset is a full ECS. Other than that, then yes. It is same spec's, memory wise, as an 500+
Like this one here....
wrote:Interesting that the TF-534 does not have this issue anymore. Would be interesting if there are any issues with 68HC000 turbo cards...
You can read a bit more about the 534 here...
From the page:
....we found bugs and reported these to Steve, he reproduced and corrected them, also we tested different Zorro II boards like Kipper2k 8Mb ram, Combitec 8Mb, HC+8MB. Theoretically it should work with other RAM cards too, however we don't own them to test...
