Reply 31860 of 52944, by dionb
MKT_Gundam wrote on 2020-01-08, 02:30:
So guys, i got the chance to buy a cheap Matrox G450.
I know, this is weak than G400 but will be a step-up than a g200 and maybe a tnt1/m64?
If you currently have a G200 it could boost performance a bit, but where a G400 about equal a TNT2 (and the G400Max can beat a TNT2-Ultra in some benchmarks), a G450 is probably on par with TNT2-M64. Not awful, but by no means a compelling gaming card. Also, OpenGL drivers were a bit of a thing, but that was the case with the G200 too, so it doesn't get worse.
Main reasons to want a G450 are the very, very good analog image quality on both outputs (the G400 has slightly better quality on the primary, but less on the secondary), far in excess of the vast majority of same-period nVidia/ATi designs. It's not just the RAMDAC that allows high resolutions, but also the filters. If you wanted to run a really high-res desktop (say 1600x1200) in those days, you would notice the difference. I bought one to use with my Sony w900 (24" widescreen CRT). Great for films & desktop work. And of course the dualhead thing - even on OSs without native multihead support you could run two screens in various configurations, which was pretty unique in 2000-ish.
These days those advantages are less relevant - any integrated VGA can do multihead, and even if they couldn't, modern OSs can. Also with digital video interfaces, analog filters aren't a thing anymore. Then again, the performance disadvantages also aren't so huge - a G450 is a perfectly valid pairing with any late P3, early P4/Athon, even if it can't outperform a GeForce or Radeon (or even a fast TNT2). You can even hook it up via two Voodoo2s for GLide (as I did at some point back in the day 😜 ).
Reply 31861 of 52944, by buckeye
Just bought this NIB Intel board luckily on the cheap. Never messed with anything socket 370 so looking forward to
building an upper tier win98 rig. The specs. will probably end up as follows:
Tualatin 1.4ghz. (unless I don't feel like messing with the bios then I'll drop down to a lesser cpu)
256mb ddr
Quadro4 900xgl or Hercules 3D Prophet II Ultra
SB Live! 5.1 sb0100
40gb IDE
350w PSU
Case-undetermined, will have to get one. Like the older Coolermasters still on sale on Newegg.
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 31862 of 52944, by MKT_Gundam
Great info guys!
The G450 is only 1VGA and has some tv tuner/image capture thing.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 31863 of 52944, by nhattu1986
I received the 3 motherboard from yahoo japan yesterday, and all three have blown cap 😁
the MSI 875p master FA is a 875p chipset yet it does not support prescott cpu, kind of weird since the mainboard is geared toward the workstation folk.
Reply 31864 of 52944, by dionb
MKT_Gundam wrote on 2020-01-08, 14:25:
Great info guys!
Then you don't have the Millennium G450 but the Marvel G450 eTV.
In this age of digital television that tuner is pretty useless, but it can do some nice MPEG2 capture from analog video sources 😀
Reply 31865 of 52944, by Predator99
Predator99 wrote on 2019-12-25, 08:40:
Scrap lot for less than 20€ (sellers pictures): - 5,25" floppy - 3.5" MFM MD - 1x Seagate MFM HD: Critical point is usually the […]
- 5,25" floppy
- 3.5" MFM MD
- 1x Seagate MFM HD: Critical point is usually the fragile flat cable at the front, unfortunately not visible on the photo
- 386 MB, for parts only...
All not looking good, but I hope some parts are working/repairable
...arrived to today in a big box without any cushioning...
1.75 MiB
3 Old Hard drives, 2 MFM 1 IDE. The ST-225 is spinning up and was the main reason to buy this, good sign.
1.73 MiB
1.71 MiB
2 5.25" Floppies:
1.76 MiB
1.75 MiB
All very dirty but I am quite happy for the price...
Reply 31866 of 52944, by Predator99
...quite surprised my price proposal was just accepted for this:
- Voodoo 3 AGP
- SS7 AGP Mainboard
- 2 XEON CPU
- some kind of SBC?
1.31 MiB
Reply 31867 of 52944, by bjwil1991
Lucky dog. I get good prices for some hardware, but nothing fancy. Hope I win the 486 computer I'm bidding on so that I can fix it (recapped an OG Xbox 1.6b motherboard before, a video card and re-traced a sound card using wires and solder, so it shouldn't be too hard).
Reply 31868 of 52944, by cyclone3d
Predator99 wrote on 2020-01-08, 20:17:
...quite surprised my price proposal was just accepted for this: - Voodoo 3 AGP - SS7 AGP Mainboard - 2 XEON CPU - some kind of […]
- Voodoo 3 AGP
- SS7 AGP Mainboard
- 2 XEON CPU
- some kind of SBC?
The SBC is made by IEI. By the looks of the cooler, my bet is the CPU is not upgradeable but not super sure what it would be... with SDRAM support, it is probably some sort of Pentium class. Looks like it has a lot of bulging capacitors as well.
The one ISA sound card is Yamaha YMF-71x based. Very nice.
Edit:
Quick google search shows that the SBC is:
IEI Rocky-C800EVR
See here for some general info:
https://www.attro.com/sbc/ROCKY-C800EV.htm
And here is the manual:
ROCKY-C800EV.pdf
356.82 KiB
65 downloads
/Edit
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 31869 of 52944, by Predator99
Hi, many thanks for finding this out! However I dont think I have much use for this as I dont own a suitable backplane.
The Souncard seems to be the Yamaha Audician 32 Plus, also very nice.
Reply 31871 of 52944, by liqmat
Predator99 wrote on 2020-01-08, 21:39:
Just sold a system with that audio card in it and a Dreamblaster S1 attached. The pair make for a very compatible DOS gaming experience.
Reply 31872 of 52944, by imi
I do :3c
meanwhile all my sbcs for them are damaged because it was one of those "let me rip all those colers off with sheer force"-type scrappers
Reply 31873 of 52944, by Bige4u
ELSA ERAZOR X2 GEFORCE256 DDR 32mb
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 31874 of 52944, by MrSmiley381
Brand new Make-It 486 has arrived today! After three or four missed opportunities to grab one of these I'm lucky to have scored this one at all. I'm excited to see what sorts of shenanigans I can undertake now.
I spend my days fighting with clunky software so I can afford to spend my evenings fighting with clunky hardware.
Reply 31875 of 52944, by appiah4
Finally managed to get me an ATI Rage 128 Pro PCI 32MB! But the card came and I see only two SDR chips on it; I guess I got a 64-bit version? 🙁
Do these count as retro yet? Because my launch 360 just RROD'ed after 13 years of service (Press F) and had to be replaced:
Reply 31876 of 52944, by H3nrik V!
- Voodoo 3 AGP
- SS7 AGP Mainboard
- 2 XEON CPU
- some kind of SBC?
Well, I see 3 Slot 2 XEONs in that image 😀
Reply 31877 of 52944, by H3nrik V!
MrSmiley381 wrote on 2020-01-09, 03:30:
Wow! And still in foil wrap? Almost a pity opening that?
Reply 31878 of 52944, by Miphee
Another lucky find for $8, my sealed Windows collection is nearing completion. 😀
    566.25 KiB
Reply 31879 of 52944, by xjas
Nice upgrade, but does it run Crysis Quake? (With the optional FPU of course.)
See if you can "beat" Elianda's 386DX/40 result in slowness.
