Reply 8220 of 53149, by Logistics
candle_86 wrote:
Creative 3D Blaster Banshee 4.99, Xfi Xtreme Music 4.99
Ah, the Xtreme Music--lovely card as they seem to be much more abundant than the other models, but not junk like the... is it the Xtreme Sound that uses the cheap DSP? I forget, but the Xtreme Music is definitely a keeper. Add kX Project for Stereo goodness!
I noticed while searching my local surplus place for the past few years that several of the Xtreme Music cards have heat-sinks on the DSP, but some do not. And I noticed physical differences in the overal thickness of the DSP on several of the boards, showing there are many revisions of this IC. I noticed mine does get hot enough that you don't want to touch it, very long. I probably should add some cooling so the heat-cycling doesn't eventually ruin the BGA setup. Not that I can't run down and get another one for $5. 🤣!
Reply 8221 of 53149, by PhilsComputerLab
With the X-Fi cards there are a lot of OEM versions out and about. I think I got three different types and only one would work with the Creative drivers. Of course I don't remember which model. Don't you hate that? When you do some testing and don't write it down anywhere, so you got to do it again 😵
YouTube, Facebook, Website
Reply 8223 of 53149, by meljor
I like the creative cards but their drivers....... just way too many cards from the same series with different chips/numbers/drivers
Reply 8225 of 53149, by Cyrix200+
jwt27 wrote:
Cyrix200+ wrote:
Another 14" VGA monitor
Looks cool! What's the dot pitch?
.28 according to the internet:
http://h20564.www2.hp.com/hpsc/doc/public/dis … p4ts.oid=218298
I like Compaq/HP for keeping all old stuff online 😀
1982 to 2001
Reply 8226 of 53149, by torindkflt
This is actually a continuation of my recent WYSE acquisition. This is the printer that was originally used with that system, I just didn't get a chance to go back and grab it until today. Unknown if it works or not because it didn't come with a printer cable, nor do I have one to test it with. 🤣
1.21 MiB
Printer Full
1.21 MiB
Printer Model
1.33 MiB
Printer Controls
1.13 MiB
Printer Label
Reply 8227 of 53149, by jwt27
I received this beast today!
It's in every way identical to the F930 I use now, except it has a flat front tube instead of curved (this also means the visible size is 498mm instead of 500mm). Other than that, specs are the same: 0.21mm, 130kHz, 160Hz.
but wait...
yeah... it's fucked. Let's hope the ridiculously expensive shipping included some insurance. 🙁
Reply 8229 of 53149, by jwt27
Arctic wrote:
Cathode Ray Monitors are parts that you shouldn't get shipped.
I always pick them up locally.
I have another (extremely rare) tube on my way... I do hope it's better packaged than this one...
Reply 8230 of 53149, by 133MHz
That corner can be seamlessly epoxied back together, totally worth the trouble if the tube didn't suffer any damage. 😉
http://133FSB.wordpress.com
Reply 8232 of 53149, by jwt27
Yeah the plastic shouldn't be too difficult, I was thinking of using cyanoactrylate glue for that. But the steel chassis is all warped too, so I'll have to take it apart completely and straighten it all out.
Tube still looks good... but I can't get it to power on. The rod that connects the power switch was misaligned so it didn't do anything at first, but even when I press it manually all I get is a faint buzz from the power supply, nothing else.
I have some good news though, the second tube arrived undamaged! Will get some pics up soon once I find space for this thing.
Reply 8233 of 53149, by Lukeno94
jwt27 wrote:
Yeah the plastic shouldn't be too difficult, I was thinking of using cyanoactrylate glue for that. But the steel chassis is all […]
Might be worth taking it apart and checking nothing came loose internally. Might be a simple repair, might not be. 😀
Reply 8234 of 53149, by jwt27
I already did, and can't see anything wrong with it... Aside from the case and chassis, everything looks okay.
Reply 8235 of 53149, by Munx
Just arrived today. Gonna have to remove some rust, but not too bad considering this cost me 7 Euros total.
2.42 MiB
Voodoo3 3000
My builds!
The Underdog - The budget K6
Reply 8236 of 53149, by jwt27
So here's the other screen.
Looks similar to the F930 at first sight, but it's quite different! This is the F980, aka the Holy Grail as I've been calling it. As far as I know the only tube ever manufactured with a 0.20mm dot pitch! Which in my book, makes it the best CRT monitor ever produced. Man, I still can't believe I finally got it. I've been looking for years for one of these, was almost starting to doubt they even existed.
It has the weird 13W3 port, BNC connectors, a serial port and USB.
specs are:
Tube: Curved shadow mask, 0.20mm horizontal.
Horizontal: 137kHz
Vertical: 160Hz
Recommended resolution: 2048x1536 at 85Hz
Max refresh rate: 1024x768 at 160Hz (or 2048x1536 at 160Hz, interlaced)
Max resolution: 4K or so at 60Hz (uh, in theory)
Reply 8237 of 53149, by obobskivich
Nice CRT there! Shame about the other one - hopefully it was insured.
And 13W3 isn't weird...if you're a Sun workstation 🤣 I have a Sun CRT on loan that has such a connector - adapters are also available if you want/need that second input and don't have an RGBHV switch; they're like $10-$20. 😀
Reply 8239 of 53149, by jwt27
Stojke wrote:
Can those monitors wear out from constant usage? I see Eizo F520, F35, F57, and so on for cheap a lot.
They do, but generally last very long. My oldest colour tube is from the early 90's and still works okay, although it's getting worse now.
Eizo is probably the best quality you could get, but only the F9xx series is really spectacular in terms of scan rates and dot pitch. I have the F77 too for example and it's not very interesting with its 1600x1200 at 75Hz.
