Constructor: PATH
First post, by sn0wf0x333
After attempting to run Constructor, it gives an error:
Error = Error reading INSTALL.DAT for PATHS
How can I go about fixing this problem?
Running Ubuntu7.10
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
by starting telling us how you installed the game and how you mounted everything.
Water flows down the stream
Reply 2 of 3, by rudcai
Constructor I have the game running in DOSBox 0.73, appears when I try to play the following errors:
Error = Unable to spool file .\Flics\HSESOWER.FLC
Error = Unable to spool file .\Flics\RESWOOD.FLC
Error = Unable to find movie file
Reply 3 of 3, by eL_PuSHeR
Write down all mounting commands you used, as Qbix suggested.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
