First post, by ElChico
Hi, when i try to launch a dos game, using VDMS, it doesn't start.
In the VDMS log i get those messages :
@E - 06:55:18.108 - SB Controller
Attempted to write to an unknown mixer register (register = 0x83,
value = 0x0b)
I tried with X-Com Apoc and Blood, and i get the same errors.
i use default parameters for SB emulaiton, and put the good parameters in the setup.
Someone get an idea on this error ?
Tried blood on dosbox, it worked, haven't test X-Com.
Thanks if you can tell me what's wrong.
Reply 2 of 2, by ElChico
Settings in the game are good.
in the setup of blood, i can test sound fx and music, and it work, but when a launch the game, i get the message i post above in the error log
fot x-com apocalypse, i didn't manage to install it with xp, i installed it with a virtual win98 et setup, on XP i can't run the setup, alone, or with VDM.
