First post, by Nicht Sehr Gut
No real point here except maybe to show that I managed to get the "Mario's Early Years" CD to (almost) run on DOSbox.
Just had to copy the 44 Megs of data files to the hard drive then edit the startup script. Apparently it hangs when it tries to load the resource files, though...
Oddly, it does this even in speaker mode (I kind of expected a problem with the Digital audio since it's meant to be streaming data).
