First post, by jal
In INT10_LoadFont() (int10_memory.cpp), after writing the font to plane 2, the following line of code enables all memory planes:
IO_Write(0x3c5,0xf);	//Enable all planes
I think this is wrong, as only the first two planes should be enabled (so the value should be 0x3). DOSbox itself doesn't seem to have a problem with it, but when testing the code on Bochs, the screen was slightly garbled. Haven't checked the behaviour on a real PC yet.
JAL
Reply 2 of 7, by jal
Compared to what? Real system or bochs bios only? (vgabios/elpin?)
Do you have some small sample of this problem?
I have tried exclusively in Bochs, see attached pictures. However, I'm pretty sure that only enabling planes 0 and 1 is actually correct, as those are the only planes written to (0 = characters, 1 = attributes). It is possible however, that enabling all planes works for VGA as well, depending on how the odd/even chaining is rigged up in hardware.
JAL
    18.04 KiB
    Bochs, normal screen (planes 0 and 1 enabled)
    18.82 KiB
    Bochs, garbled screen (all planes enabled)
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
Well the bios is quite "destructive" with the font functions, so it could actually
be correct that it (real vga bios) doesn't care about setting/restoring the
correct plane setting.
Got to look up how some other bioses handle this...
Reply 5 of 7, by jal
wd wrote:
ibm vga stuff: […]
ibm vga stuff:
seg001:123A                 mov     dx, 3C4h
seg001:123D mov ax, 302h
seg001:1240 out dx, ax
So 3 it seems for those.
It is what I expected, as it makes sense that only planes 0 and 1 are enabled, since these are chained. Allowing access to 3 and 4 (where the character definitions reside) doesn't make too much sense.
JAL
Reply 7 of 7, by jal
wd wrote:
Well they could have saved/restored the values, too, but guess they
assumed strict default-textmode thus used those fixed values.
S3 does the same btw.
Ok, so Dosbox should do the same then I guess.
JAL
