First post, by ConjurerDragon
- Newbie
I read on the DOSBOX website that the new version 0.72 should be able to run Battlespire (The Elder Scrolls Legend: Battlespire) and wanted to try if it would work now on my PC as it never worked in earlier versions of DOSBOX.
I use Dfend Reloaded and I already have followed the instructions to be able to play the game from the harddisk instead of from the CD-ROM here:
http://www.uesp.net/wiki/Battlespire:Technical_Info
However I do get nothing but either a black screen, a click of the monitor and am back to Dfend Reloaded - or on another try a black screen that stays untill I reboot the machine 😕
This is the configuration text that Dfend puts out after I used the wizard to make a profile and modified memory used to 63 MB:
[sdl]
fullscreen=true
fulldouble=true
fullresolution=original
windowresolution=original
output=surface
autolock=false
sensitivity=100
waitonerror=true
usecancodes=true
priority=higher,normal
mapperfile=H:\DOSBOX\D-FEND RELOADED\mapper.txt
[dosbox]
language=H:\DOSBOX\D-FEND RELOADED\DosBox\Deutsch.lng
machine=vga
captures=H:\DOSBOX\D-Fend Reloaded\Capture\Battlespire
memsize=63
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=auto
cycles=4000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=2048
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=false
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=1
dma2=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
tandy=off
tandyrate=22050
disney=false
[dos]
xms=false
ems=false
umb=true
keyboardlayout=GR
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
Serial1=Disabled
Serial2=dummy
Serial3=disabled
Serial4=disabled
[autoexec]
@echo off
SET PATH=Z:\
mount C "H:\DOSBOX\D-FEND~1\VIRTUA~1\"
call SPIRE.BAT
exit
Is there anything obviously wrong that it won´t work?
I´m using Windows 98SE
