First post, by Silent Loon
- Member
I think about building a system with a slow Pentium 1 cpu that should rely on passive cooling. I have a Pentium 75 which of course does not need a fan , but the case I want to use is quite narrow and so the P75 gets quite hot.
I wonder if a slowed down Pentium (i.e. Pentium 200) would stay cooler running at 75mhz than the original P75?
Second I would like to know if there are Socket 5 / 7 cpus that allready have locked multipliers, so you can't slow them down (I remember that I couldn't change the speed of my P233MMX).
Third, I could also use a 486-board with a Cyrix 5x86 cpu normally running at 100mhz (3 x 33mhz) that I could slow down to 75mhz (3 x 25mhz). Has anyone experience with this type of cpu? Is this the "coolest" solution for a high-end 486 / low-end Pentium system? ( As the core of the Cyrix is allready manufactured with 0,65µm technology)
