Leisure Suit Larry 7 - mouse very hard to control
Having problems with a specific game or application? Post your problems here!
Postby zzenn » 2008-3-25 @ 18:46
I'm playing the dos version of LSL7 with dosbox 0.72 and everything is fine except for the mouse. It moves very fast/jerky across the screen and is practically impossible to control. Eventually it tends to get stuck on the left side of the window.
I tried changing the config file as per LSL6 recommendations for a busted mouse, but that only made it worse and also affected the sound.
Okay, my specs:
Dell vostro 1500 laptop
Motherboard - I dont know
Processor type and speed - Core 2 Duo 1.6
Amount and type of RAM - 2 GB
Video board w/ RAM amount and type - Nvidia GS8400
Sound board - Sigmatel (barf)
Operating system - Windows xp sp2
Game name (and version, if applicable) - Leisure Suit Larry 7
This problem happens every single time.
I guess the video mode is vesa? Not really sure.
I hope someone can help me to help Larry get his groove on ;)
zzenn
Re: Leisure Suit Larry 7 - mouse very hard to control
Postby zzenn » 2008-3-26 @ 05:18
Okay the mouse is working now. I edited the dosbox config file and disabled autolock for the mouse. Then made sure sensitivity was at 100.
The only problem now is the sound. It is kinda glitchy. I guess I will try some more settings :)
zzenn
Postby zzenn » 2008-3-26 @ 06:42
Arrgh, now the game is crashing. I notice the glitches get worse when I move the mouse and then soon after the game dies.
Can anyone please post their dosbox config for getting LSL 7 Love for Sail to work?
zzenn
Postby zzenn » 2008-3-26 @ 08:01
I'm experimenting with settings. It seems a high number of cycles makes the game more responsive and playable. Unfortunately, that also means the sound gets worse.
Isn't there ANY way to run this?
I also tried VDMSound, but it's painfully slow. If I move my mouse, it then crashes. If I don't resolve this soon, I'll install ms-dos in virtualbox and give it a go the old-school way.
zzenn
Postby Qbix » 2008-3-26 @ 08:11
dunno it ran fine on my pc. standard config which is a lot slower then yours
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby zzenn » 2008-3-26 @ 08:47
Okay I figured it out, more or less. After disabling various services it now runs fine. Feel free to delete this topic.
zzenn
Return to DOSBox Games/Apps
Who is online
