First post, by Unregistered
Hello,
I have a quick question....
If I register Glidos can I use it on my computer and my daughters computer with one $10 registration, or do I need to buy two $10 registrations?
I want to play the old carmageddon, and she want to run the old Tomb Raider.
Just curious what the license issues are for glidos and multiple systems.
Thanks for your time.
belboz
Reply 1 of 4, by Carrera
If memeory serves, the key is tied directly to the hardware on your computer so it is $10 per computer.
Paul can correct me, of course.
Reply 2 of 4, by Glidos
The unlock service gives you codes for two computers, plus another every six months, to cope with upgrades. And for people with special circumstances I can set up more.
On the other hand, if you want it for ten computers, or the like, then I might be a bit suspicious.
Reply 3 of 4, by Unregistered
Well that sounds perfect for my computer and my daughters computer.
How does the key service work? I figured I would get a code for the hardware based on the computer I register on. Do I just go back to the unlock service on the second system and get a code too?
Thanks for the feedback. I will definitely be registering soon.?
Reply 4 of 4, by Snover
When you install GliDOS on the computer you get a "GlidosID" that you then insert into the script on the GliDOS website. It then gives you the four keys you need to activate your copy of GliDOS.
Yes, it’s my fault.
