First post, by joe67
joe67
Offline
Hi, I'm new of using dosbox, and it's simply great! I've got just one problem with it, I'm using an old dos software that requires the numeric keypad working as itself, unfortunately so far it only moves the mouse cursor and no numbers can be written.
I lso tried to modify the dosbox.conf, but the only result I got was that now the numeric keypad doesn't work at all, not even as a mouse.
I'd really appreciate any suggestion to make it work properly.
Thanks in advance.
Joe
