SDRmap v6.5 on Dosbox
First post, by DAD
Hey, I have an old land survey program called SDR mapping & design v6.5 which I am struggling to get onto my new work computer that has Windows Vista. I've managed to get it going in Dosbox but am getting weird errors.
Any help on this topic would be appreciated.
Reply 1 of 26, by MiniMax
Rank Moderator
Moderator
Did you try looking up "weird errors" in the documentation?
_________________
Reply 2 of 26, by DAD
Yeah, sorry about the late night description. Family was sick and I was trying to get a project completed by the end of the weekend.
Dosbox has the error:
Warning: file creation failed: c:\mapsys\MAPDATA\VARRAY.DAT
I wonder if I'm getting the error above because of the weird administration rights vista seems to run for everything.
I tried another way of getting SDRmap to work by installing the Windows XP drivers for my graphics card to allow command prompt to go full screen. This has worked pretty well, but the screen is still quite dull and I still need to use Dosbox to start a project in SDRmap for some reason.
I hate Windows vista. I might get the boss to upgrade to NT. Even XP would suffice.
Reply 4 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
well if you give yourselves acces to the folder in question it should work.
You might want to check if
c:\mapsys\mapsdata exists
Water flows down the stream
Reply 5 of 26, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
especially if that folder exists in that location within your mountings. To me it sounds like your installation is broken. Meaning the program looks for files where they don't are in your mountings. Usually that is fixed by installing from within Dosbox. Of course you have to have writing permissions.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 26, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 7 of 26, by DAD
Current Computer:
Hewlet Packard Laptop Compaq 6710b, Windows Vista Business 32-bit
I had SDR working one my home computer in Windows 2000.
I copied it directly over and tried to load it using Command Prompt.
Vista directed me that cmd does not operate in fullscreen mode.
I followed some advice to install xp graphic drivers to allow fullscreen mode on cmd, but SDR and a few other programs did not work properly.
I have installed DOSBox and have SDR installed under the following directory:
C:\DOSBox-0.72\MAPSYS
I then:
Mount c c:\DOSBox-0.72
SDR loads fine and in the initial screen it prompts the following functions:
Continue recent job (filename)
Start new job
select and existing job
Configure system
Automatic processing
These all work fine initially but once in SDR and any one of these functions are selected SDR crashes and displays the following message:
Runtime error 6 at 003d:20E8 in module DQMLIB.dll
This is also a file under c:\DOSBox-0.72\MAPSYS
For all intent and purpose SDR is working... it's just causing me a major headache every time I need to select one of those functions as I need to reopen SDR each time.
fullscreen=false
fulldouble=false
fullresolution=1024x768
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
language=
machine=vga
captures=capture
memsize=63
nosound=true
mpu401=intelligent
device=default
config=
sbtype=none
gus=false
pcspeaker=false
joysticktype=none
xms=true
ems=true
umb=true
keyboardlayout=none
ipx=false
Reply 8 of 26, by DosFreak
Very rarely do DOS programs use .dll's. Are you sure that .dll isn't a Windows .dll? If so then it will not work in DosBox.
It's possible that your DOS program used some Windows functionality in that .dll which of course would not work in DosBox.
Make your games work offline
Reply 9 of 26, by DAD
Thanks heaps for the advise! SDR is definitely dos-based, perhaps a later windows patch has been slammed on top of it.
Love DOSBox by the way... brought back the good old days of X-com Enemy Defence and Dune! Wife wasn't so happy about it... but she can't stop me when she's asleep 😉
Keeps complaining about marrying a sci-fi computer nerd.
She was a virgin to the likes of "Star Wars" and "The Last Starfighter" until I came along. She hadn't even watched "the Goonies" for crying out loud?!
Reply 12 of 26, by Napstr
Hi
I am using an older version of DosBox (071) and it throws me out every now and then and also I cannot use the print to a file option - when I try and print it crashes saying "the disk is full" which is obviously not correct as I can create a job and save my data - just not print to a txt file
Reply 14 of 26, by Napstr
Don't think it's the version that is causing the error - the software will run straight on XP but has conflicts with certain machines hardware drivers - and dosbox seems to resolve the conflict allowing it to run although there are certain problems experienced around save times
    77.89 KiB
    This is an example of whats happening when the main error occurs
Reply 16 of 26, by wd
Rank DOSBox Author
DOSBox Author
Then use the new version.
As you get a nice error message about a specific file, check its permissions
and file attributes (remove a hidden/readonly attribute for example).
