First post, by siffland
I am trying to figure out if DOSbox will work for my purpose. I have an old laptop with a 300MHZ processor and 192MB of ram with FreeBSD 7 installed (I use it for programing and writing scripts and such). I would like to install DOSbox to play a few games. They are from around 1990 (mostly sid meyer games like pirates and covert action). I read the minimum system requirements and it said a 400MHZ machine would be required to run. Do you think a 300MHZ will run the games without a problem (the games run fine under DOSbox i put it on my windows machine so that is not an issue, just the speed of the laptop)? I just do not want to install it and all of its librarys if if it will not run.
Thanks
Sean
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
I could be wrong, but I don't think DOSBox will run on top of FreeDOS. So you would need to install at least some kind of Windows, probably WinNT 4.x, in a dual-boot configuration perhaps, before you have a chance of running DOSBox.
You can not run the games you mention directly from FreeDOS? Problem with the soundcard/devices in that laptop?
Edit: Arrggh!!! I can not read. The original poster said FreeBSD, not FreeDOS! Forget all that I wrote.
_________________
Reply 2 of 3, by ADDiCT
MiniMax, i think there's a slight difference between FreeDOS and FreeBSD... (; I think it's totally possible to run DOSBox under FreeBSD (which is more or less a Unix flavour, like Linux - yes, i know the whole truth is a bit more complicated (; ).
siffland, DOSBox is quite CPU intensive, in general. The latest version (0.72) has brought a huge performance leap (with the dynamic core), but you'll still need a fast processor for good framerates (especially with action games). I'd say your processor will only be able to deliver a handful of FPS, but that's just a guess. It might be enough to play "slow" titles, but i highly doubt you will have much fun playing the games. The next problem would be the RAM. You'll need RAM for your OS, and for the emulated machine, of course. Your 192MB are just sufficient for the OS and some apps, i think.
In my opinion (and from my experience), you'll need at least something in the P4/2Ghz class with 512MB RAM for fluid play, and that's even with "slow" titles. I'm using DOSBox with a P4/2.6Ghz/1GB RAM, and i'm seeing occasional "hiccups" with "slow" games - demanding stuff, like Blood in 800x600 runs at unplayable framerates. The same machine is able to run modern 3D games, like STALKER oder C&C3 at stable framerates (with less-than-maximum-details, of course).
Bottom line: try it. "Playability" and "Fun" are measured on a subjective level, so your play experience might differ from mine (other other's).
