First post, by Danicela
In the produced avi we get music on main menu, but we don't get it in games, because it's on the cd? how to get it?
Note : We hear the music in the game.. we just don't hear it on the produced avi.
Reply 1 of 19, by leileilol
The CD audio sound buffer isn't part of the PCM buffer DOSBox outputs sound with.
Reply 2 of 19, by Danicela
Ok I was nearly sure it was a problem with the audio cd feature, but now, how to get this sound in the video.
Reply 3 of 19, by wd
Rank DOSBox Author
DOSBox Author
Hm maybe try it with a cue/bin pair mounted with imgmount, that grabs the
audio data in a different way. Don't know if it's recorded that way though,
maybe somebody else already tried it.
Reply 4 of 19, by Danicela
I'll use another capturer that captures only sound in the same time and then mix both video and sound, in waiting a better solution.
Reply 5 of 19, by wd
Rank DOSBox Author
DOSBox Author
See above.
Reply 6 of 19, by ADDiCT
I don't fully understand the OP's problem, but it seems he (or she) is trying to capture video with DOSBox, and doesn't get music in the captures, although it's playing during the capture.
WCII has CDDA and MIDI soundtracks, AFAIK. I don't know if the CDDA music is captured (the OP should try what wd has suggested), but i'm quite sure the MIDI won't be captured, because it's played "outside" of DOSBox, by whatever MIDI device Windows is configured to use. The solution would be, as the OP already has noticed, to capture the music with a different capture program, and then mix it with the captured video.
Hmmm... Why am i writing this? (;
Reply 7 of 19, by Danicela
Ok but how i create the iso ?
Reply 8 of 19, by MiniMax
Rank Moderator
Moderator
Ever head of Google?
_________________
Reply 9 of 19, by leileilol
If you create an ISO you won't get cd music
You will want to create a BIN/CUE
Reply 10 of 19, by Danicela
I meant... with DosBox.
Why this difference?
Can DosBox do it or I need another program to do it?
Which one is the best?
Reply 11 of 19, by wd
Rank DOSBox Author
DOSBox Author
DOSBox is a pc emulator and no iso creation utility.
Because the iso format doesn't store audio tracks per definition.
Reply 12 of 19, by Danicela
Hmm.. that's why there was not music with .iso cd.. (with audio tracks)
Which iso creator (cue/bin) is the best?
Reply 14 of 19, by Danicela
OK I did and I managed to reproduce one thing I've done I don't know how without the .bin : Having strange music, it's the music, but played in a different way, like real MIDI ^^ this is recorded, but on the non bin I have both Sound Blaster for sound and music set, and on the bin one too, but the music is not the same 😒 why?
Reply 15 of 19, by Danicela
Finally I use DosBox in normal mode and I capture the video with CamStudio and all the sounds and music are ok.
Reply 17 of 19, by franpa
You could have just set your sound card to record what it outputs then use Microsoft Sound Recorder >.>
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 18 of 19, by ripa
When you record using Dosbox you get bitperfect output and even if Dosbox chokes because of the lack of CPU time, the recorded output won't have any of that.
If you record video and audio separately (with the audio being recorded by a separate piece of software), they would easily go out of sync, because the recorded video won't have any video drops resulting from the lack of CPU time, but the audio will have.
Reply 19 of 19, by Danicela
Finally I prefer my answer with CamStudio, I don't need to do other work of mix, and I use the same method but with Virtual Box for Starcraft.
It's strange because the sounds are not the same with War2 installed on a Virtual Box machine.
