First post, by DosFreak
http://files.filefront.com/Command+Conquer+Hi … ;/fileinfo.html
Forum thread:
http://forums.ea.com/mboards/thread.jspa?thre … 366461&tstart=0
This totally rewritten patch allows you to switch C&C95 to 1024x768 resolution and back without needing any additional tools. The game will read the resolution setting straight out of the game's original configuration file, which can be edited with the updated configuration tool.
This also means that, unlike in the older patch, you can still play the game in its normal resolution, even after installing this.
Make your games work offline
