DOSBox setup on mac
First post, by spectrum
Hello all,
i have installed successfully DOSBox on mac, DOSBox.app is intalled in my /Applications folder.
Now i need to have DOSBox executable in the path, to execute it from the command prompt, how should be the correct way to set it up ? DO i have to include it in the PATH variable ? Or should i do in /usr/bin a DOSBox symblolic link to the executable ?
greetings, spectrum
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
A symlink sounds like a good idea. But perhaps not in /usr/bin. Why not make a ~/bin directory, put the symlink in ~/bin, and put ~/bin on your PATH ?
Or you could make an alias....
_________________
Reply 2 of 2, by IIGS_User
I don't know about the path thing, but the executable part of the application is stored in "DOSBox.app/Contents/MacOS/DOSBox"
Klimawandel.
