First post, by Unregistered
Hi,
I've come here from a link from the Glidos website, I can't get sound to work in the Tomb Raider 1 game with Glidos - it links to a thread in the other part of this forum (where I can't post) where it says I need to install something called VCRDIST and then install Vdmsound(1)win9x.alpha1 - well I've downloaded them both but VCRDIST doesn't seem to install at all on my Win98 PC - it asks me to reboot which I did but after that theres nothing installed at all in C:\VDMSOUND or anywhere else for the that matter - although when I run the Vdmsound(1)win9x.alpha1 intall.bat file I get the message "DllRegisterServer in VDMConfig.dll succeeded" window pop up and after I've closed it I get the message in the intall.bat DOS window: "IMPORTANT !!! Please edit C:\AUTOEXEC.BAT and add the following line:
SET VDMSPATH=VDMSOUND
...where C:\VDMSOUND is the directory where VDMSOUND was installed (i.e. the current directory)
Now the problem is - is the unzipped vdmsound(1).win9x.alpha1 folder the fabled VDMSOUND folder and secondly, how do I edit the AUTOEXEC.BAT file anyhow?
Reply 1 of 2, by Nicht Sehr Gut
Originally posted by Unregistered I've come here from a link from the Glidos website, I can't get sound to work in the Tomb Raider 1 game with Glidos - it links to a thread in the other part of this forum (where I can't post) where it says I need to install something called VCRDIST and then install Vdmsound(1)win9x.alpha1
Be aware that the Win9x version of VDMSound is basically an "experimental Alpha". That means if it works properly for you, great; if it doesn't, don't expect a fix unless someone comes along and offers to code an update.
..well I've downloaded them both but VCRDIST doesn't seem to install at all on my Win98 PC - it asks me to reboot which I did but after that theres nothing installed at all in C:\VDMSOUND or anywhere else for the that matter
It shouldn't place any files in the VDMSound directory, almost all of them will be placed in the SYSTEM directory. The files (most of them anyway) are as follows:
File 'C:\WINDOWS\SYSTEM\msvcirt.DLL' updated. File 'C:\WINDOWS\SYSTEM\msvcrt.DLL' updated. File 'C:\WINDOWS\SYSTEM\comctl32.DLL' […]
File 'C:\WINDOWS\SYSTEM\comctl32.DLL' updated.
File 'C:\Windows\System\Advpack.dll' updated.
File 'C:\Windows\System\Asycfilt.dll' added.
File 'C:\Windows\System\Atl.dll' added.
File 'C:\Windows\System\Comcat.dll' updated.
File 'C:\Windows\System\Olepro32.dll' updated.
File 'C:\Windows\System\Oleaut32.DLL' added.
File 'C:\Windows\System\Mfc42.DLL' added.
File 'C:\Windows\System\Comctl32.DLL' added.
File 'C:\Windows\System\Msvcirt.DLL' added.
File 'C:\Windows\System\Msvcp60.dll' added.
File 'C:\Windows\System\Msvcrt.DLL' added.
These, by the way, are not "VDMSound files", they are files needed to run programs created with "Visual C".
Correct. That needs to be done before attempting to run it.
Errr...No. You have to create a folder called VDMSound in the root directory of C:
You should've copied the files from the zip file into that directory before attempting to run the INSTALL.BAT file. Now you've got some screwed-up Registry entries. Not sure how to fix that. Vlad might know.
...and secondly, how do I edit the AUTOEXEC.BAT file anyhow?
If you have to ask this question, then you might want to avoid running Alpha programs. They are not designed as easy, user-friendly programs, but as experimental programs that require the user to have at least moderate level of computer knowledge.
To answer the question, (if you are editing within Windows) just right-click on the file and choose Edit.
BTW, we need more data on your System specifications (especially the sound card and it's settings). Did you try matching TombRaider's audio setup with your card's audio settings first?
Reply 2 of 2, by Unregistered
's ok I was only trying to get GLIDOS to work with TR and thought you had to use this VDMsound thing as there was a link from the GLIDOS website to this part of the forum, but to be honest this place really isn't for your average joe -
I managed to get the Soundblaster sound option working instead so it's not a problem.
Thanks for the reply.
