error "illegal command: win" when installing Return to Krondor
Having problems with a specific game or application? Post your problems here!
Postby plantfood » 2008-6-08 @ 15:59
I just installed DosBox and am trying to install Return to Krondor. I created a directory for my game and mounted it as the c drive, and mounted the cd-rom drive as the d drive. I switched to the d drive and I can run the directory command and see the file "setup.exe" in the list. However, when I type "setup" or "setup.exe" the prompt says "win setup.exe" and then the error "illegal command: win". I didn't type "win". What am I doing wrong?
Thanks in advance.
Kelly
plantfood
Re: error "illegal command: win" when installing Return to Krondor
Postby leileilol » 2008-6-08 @ 16:05
PRO TIP: Windows games run on Windows
User avatar
leileilol
Postby DosFreak » 2008-6-08 @ 16:06
Return to Krondor is a Windows game.
Game Acronym List
DosBox CVS Builds
DosBox Feature Request Thread
DosBox FAQ
PC Game Compatibility List
"Who's got time to read all the way down to the bottom of an email?"
User avatar
DosFreak
Postby plantfood » 2008-6-09 @ 04:24
Ok, duh, but it's a 16 bit game and I read somewhere else on the Web that 16 bit games run on dosbox because Win 3.1 overlayed dos. Do you have any suggestions on how to run a 16 bit game in win xp?
plantfood
Postby leileilol » 2008-6-09 @ 05:29
I dunno, but... have you tried running it in Windows XP!
User avatar
leileilol
Postby DosFreak » 2008-6-09 @ 10:30
16bit Windows games run fine in Windows XP 32bit.
16bit Windows games only run in DOSBox if you install Windows 3.1 in DOSBox.
Is Return to Krondor a 16bit game? and would it work in Windows 3.1? Since it was released in 1998 somehow I doubt it.
Return to Krondor works fine in Windows XP, duh
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby Miki Maus » 2008-6-09 @ 13:18
Both Wikipedia and MobyGames mention that Return to Krondor is game released for Windows 95 which is logical as it came out in 1998.
Offtopic:
Did anybody else notice disturbing trend on Internet where people are recommending DOSBox for any game that doesn't run on WinXP/Vista? It seems that it doesn't matter to them if it was made for DOS or Windows. :disapproving:
User avatar
Miki Maus
Postby wd » 2008-6-09 @ 13:29
That might mean dosbox is too user friendly, let's do something against this!!
wd
DOSBox Author
Postby Qbix » 2008-6-09 @ 13:36
agreed
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby DosFreak » 2008-6-09 @ 13:38
We could make people have to type in pig latin. :)
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby leileilol » 2008-6-10 @ 05:33
Betrayal of Antara is Win16 though
Return to Krondor is definitely Win32, and also OMG 3D ACCELERATEZED
User avatar
leileilol
Postby DosFreak » 2008-6-10 @ 09:59
collector wrote:inway romfay hetay ommandcay romptpay?
Esyay eway avehay emthay imetay igpay atinlay inway ethay
ommandcay omppray. Ouldshay etgay idray ofway allway ofway ethay
oobsnay.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: Yahoo [Bot] and 0 guests
