First post, by Unregistered
Although VDMDrv was installed in the machine of Japanese Windows XP, the following errors come out and do not start. How is what is necessary just to really carry out? "Unable to instantiate emulation module 'Ad lib Player' 0x800401f3-Invalid class string(C:\Progra-1\VDMSound\VDMS.INI:217) Do you want to continue?" OS:Windows XP Pro SP1 CPU:Celeron (Japanese) 550 MhzSound Card:ESS Maestro 2E PCI (WDM)
    74.03 KiB
    156 downloads
Reply 1 of 1, by Snover
Ooh, cool, a real live Japanese person! ^__^
You must install with Administrator account in order for the files to register. This is probably what is causing the problem. You may also want to go to "Add/Remove Programs" and "Repair" the install.
Yes, it’s my fault.
