First post, by sax_mad
Hi, I've recently downloaded DOSBox because I wanted to be able to play Toonstruck on my XP. I got it running fine (if a little slow) with sound. However, something happened which stopped DOSBox from being able to find my audio device. I thought it was downloading and using DOS32A, but I changed it back, and it still doesn't work. I've also tried re-installing it, and tried changing the Soundblaster settings, but still nothing. I didn't really know what I was changing, so I didn't mess too much.
When I open DOSBox, the status window says:
CONFIG:Loading primary settings from config file C:\DOSBox\dosbox.conf
MIXER:Can't open audio: DirectSoundCreate: No audio device found , running in no sound mode.
MIDI:Opened device:none
Oh yeah, and I tried typing in MIXER /LISTMIDI and it did nothing.
Can anyone help me please? Thanks
EDIT: After posting this, I've found out that my computer hates me, it doesn't recognise the sound device any more that used to work, but now don't, on a laptop with built in speakers. Thanks anyway...
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Check if directx is fully working (dxdiag tool) and be sure your sound card
is correctly installed/has functional drivers.
Reply 2 of 3, by sax_mad
Thanks! Seems to be working now (a restart does wonders!)
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
Maybe there was just some app still in the background (hanging or whatever)
that occupied the sound module.
