First post, by OSH
Ok. I have original ISO from Theme Hospital.
I've mounted is as ISO and run setup. After I've chosen language version DOSBOX hangs and in the console window I saw this:
Here is my DOSBOX config:
fullscreen=false
fulldouble=false
fullresolution=0x0
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
pixelshader=none
usescancodes=false
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory DOSBox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames DOSBox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,hq2x,hq3x,
# 2xsai,super2xsai,supereagle,advinterp2x,advinterp3x,
# tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
# If forced is appended (like scaler=hq2x forced), the scaler will be used
# even if the result might not be desired.
# Hardware modes (all except surface) also support hardware2x or hardware3x, use for hardware scaling.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
# auto switches from normal to dynamic if appropriate.
# cycles -- Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# You can also let DOSBox guess the correct value by setting it to max.
# The default setting (auto) switches to max if appropriate.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=normal
cycles=max
cycleup=500
cycledown=20
[vga]
# svgachipset -- Select one of the following supported SVGA chipsets:
# s3 (default), et4000, et4000new, et3000, pvga1a, or none.
# Full chipset name (like 'Tseng ET4000') will also work
# as long as it contains one of the strings above.
# videoram -- Amount of video memory on emulated SVGA. Not all emulated
# chipsets support this setting.
…Show last 165 lines
svgachipset=none
videoram=2048
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,mt32,none.
# mt32rate -- Sample rate of MT32 emulation
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=uart
device=default
mt32rate=22050
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3,hardware.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
# hardwarebase -- base address of the real hardware soundblaster:
# 210,220,230,240,250,260,280
sbtype=none
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=44100
hardwarebase=220
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=D:\ultrasnd
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation. Covox Voice Master and Speech Thing compatible.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=false
[joystick]
# joysticktype -- Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks,
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# timed -- enable timed intervals for axis. (false is old style behaviour).
# autofire -- continuously fires as long as you keep the button pressed.
# swap34 -- swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap -- enable button wrapping at the number of emulated buttons.
joysticktype=2axis
timed=false
autofire=false
swap34=false
buttonwrap=true
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq.
# for directserial: realport (required), rxdelay (optional).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[parallel]
# parallel1-3 -- set type of device connected to lpt port.
# Can be reallpt (win32 only)
# parameter:value.
# for directlpt: realaddress (the base address of your real parallel port).
# Can be 378, 278 or 3BC. The first two can be ECP ports.
# Default: 378
# You have to install the PortTalk driver from
# http://www.beyondlogic.org/porttalk/porttalk.htm first.
parallel1=disabled
parallel2=disabled
parallel3=disabled
[glide]
# glide - Enable glide emulation: true,false.
glide=false
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support.
# keyboardlayout -- Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
mixer master 30:30
mixer sb 30:30
mixer gus d-40
mount C D:\Emulatory\PC\DOS\DOSBox-0.72\DOSBOXCVSykhwong -freesize 900
mount D "D:\Gry\
imgmount e "D:\Gry\test\hospital.iso" -t iso
And system specs:
Athlon64 2 GHz, 1 GB RAM, Radeon X1550, Windows XP SP2
I've tested various combinations EMS/XMS/UMB, various processor's cores, various DOSBOX versions (CVS and official versions), I've replaced dos4gw with newer/older version, disabled sound output, I've used also DOS32A - without success. I still don't know, where' the rub?
Reply 1 of 6, by t0mme
Have you tried making a new ISO?
* Intel Pentium Dual-Core e2180 @ 2Ghz | 3GB Ram | Asus Geforce 9600GT 512MB | Vista Basic *
* AMD Sempron XP 2800+ @ 1,6Ghz | 1GB Ram | SiS M760GX | Windows XP | Linux Mint 8 *
* Dedicated DOS-machine obsolete since DOSBox 0.73 *
Reply 2 of 6, by OSH
I've copied all files from CD and this also doesn't help. But I hadn't any read errors by copying from CD...
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
Try a cue/bin and be sure you're mounting it correctly using imgmount.
Reply 4 of 6, by OSH
But I think, the problem isn't with CD, because I've made directory on my HDD copied all files from CD and I've got the same error. Has anybody here Theme Hospital CD and ran installer under DOSBOX?
Reply 5 of 6, by t0mme
Yeah, it runs like a charm. The bottom screenie is right after the language selection, where it accesses the cd-rom. All I can think of this moment is that your cd is damaged.
Reply 6 of 6, by OSH
You was right t0mme...a file called ULTRA.DIG in the DOSSETUP/SOUND directory was damaged. After replacing, it works. Big thanks for all for help! 😀
