First post, by diego gr
It's possible to connect two computers using internet with VDMSound?
I want to play DOS games that use the IPX network protocol
Better use Dosbox. It has IPX tunneling through TCP/IP. If you want to give it a try, look for the command IPXNET at the readme. You will also have to forward the port to the other PC or to use some VPN.
Anyway, games from the Dos era rarely like the latency of an internet connection, so dont be dissapointed if it doesnt work.
