First post, by lc
I have a C program using "putchar(\a)" to make a beep under dos.
but under Dos bos it doent work.
any ideas to solve it
I thank you in advance
Reply 1 of 13, by wd
Rank DOSBox Author
DOSBox Author
One topic is enough please.
BEL is not supported. Use some small program that deploys the pcspeaker
if you really have a need for that.
Reply 2 of 13, by lc
I thank you for you quick responce,
wath do you means about "deploys the pcspeaker"?
is it the same issue for putchar(\0x07);
best regards
Laurent
Reply 3 of 13, by wd
Rank DOSBox Author
DOSBox Author
Yes, this is the same character.
Write some program that turns on the pcspeaker, waits for a short
while, then turns the pcspeaker off. Then you can just execute that
program instead of your putchar() thing.
Reply 4 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Or just make a patch for DOSBox 😀
1+1=10
Reply 5 of 13, by wd
Rank DOSBox Author
DOSBox Author
[note to self: kill hal by times] 😜
Can't think of any use for it at the moment though (the BEL thing, that it).
Reply 6 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I didn't say anywhere he should bother you to put it in CVS 😘
1+1=10
Reply 7 of 13, by wd
Rank DOSBox Author
DOSBox Author
no but patches++
Reply 8 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Come and get me 😜
1+1=10
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
Gotcha, but everytime i beat you you produce a *beep* how odd.
Reply 10 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I'm afraid you don't do enough damage...
(I like this one as it makes w95 shut down gracefully instead of lock or crash when told to restart)
1+1=10
Reply 11 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
there is an int 10 string printfunction as well. Saves a few calls 😉
Water flows down the stream
Reply 12 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
ah=13h?
I'd have to mess with guest memory though
1+1=10
Reply 13 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
ah yes. true. Stick with the loop then
