Amigaz wrote:http://www.gigabyte.com.tw/Products/Motherboa … ductName=GA-5AA […]
It has an AMD K6-II+ 550mhz, 768mb RAM
Geforce 256
Geforce 2 GTS, Ultra
Hercules 3D Prophet II MX
Asus V7100 Geforce 2 MX
It goes thru the BIOS Post, as it's about to boot it just stops 😵
Hmmm, that IS an AT board, so it could as well be the power issue... Which revision do you have? According to some fragments on the net, revision 1.x boards have a very weak power converter, revision 2.x should work better.
If you're using an AT PSU, swap it for an ATX model (the board has connectors for both types). In case you're lucky, the board then takes 3.3V directly from the PSU instead of converting them from 5V through the weak power regulator. Try the GF2MX cards, as the other ones draw much more power.
As a last resort you could try to exchanging the power regulator for a stronger one.
swaaye wrote:I suggest sticking with Voodoo cards for such systems. Even an overclocked K6-III+ can not really fuel a GeForce or Radeon anyway. Voodoo5 is the perfect match for those CPUs because Glide was a much superior API (lower CPU overhead, etc) compared to D3D back then.
Correct, if you want to max out a fast K6 system without trouble, take a V5. But to really enjoy a V5 card, you'll need at least a GHz CPU 🙄
Amigaz wrote:wonder if it was the form factor that restricted them making a technical good board
To a certain degree, yes, but primarily it was price. In order to compete against Intel with their awesome BX chipset, Socket7 hardware had to be cheap. That explains the wimpy power regulators and the generally low quality of later Socket7 boards.
