First post, by deeped
Hi all,
Im trying to use an older Sound Card 16 CT4180. I guess its PnP technology because no jumper I found. After connecting it says it uses 220 port, 9 IRQ and 1, 7 DMA.
Only a few games can use it. How to change the Port, IRQ, DMA etc parameters? Sadly I have no install disk for it. I have a old hardware (2001). I got an install what requered a CTCM program. That CTCM was installed (it was hard because it "thought" that it is in Windows allways). I used to used a Sound Blaster Pro2 at 240 port with 7 IRQ. Sadly, most games cant handle the 9 IRQ. Is the PnP to configure the parameter of card, instead of setting jumpers?
The IRQ 7 is free. Any idea to use the card, or any installer program? If someone remembers for those "old times" please reply! Im only interested in real DOS mode, not XP.
