First post, by jcdutton
Hi,
Is it possible to use dosbox over ssh, but without a X display?
I.e. Only permit text modes in dosbox, and therefore dosbox would only have to send ascii code updates to the screen, instead of bitmaps when the screen gets updated.
Something like a ncurses output for dosbox, instead of vga would be nice.
Reply 1 of 13, by wd
Rank DOSBox Author
DOSBox Author
Even text mode uses (has to use) a graphical surface in dosbox, so this won't work as is.
Reply 2 of 13, by MiniMax
Rank Moderator
Moderator
Why do you want to do this?
_________________
Reply 3 of 13, by leileilol
It'd be cool to play text games in pure text mode. Dosemu already has support for this as a dumb terminal "video card".
long live PCem
Debian's fucked
Reply 4 of 13, by MiniMax
Rank Moderator
Moderator
Why would you want to play in pure text mode?
_________________
Reply 5 of 13, by leileilol
Why require the start of an X server to just only play text mode games?
long live PCem
Debian's fucked
Reply 6 of 13, by MiniMax
Rank Moderator
Moderator
Why not?
_________________
Reply 7 of 13, by leileilol
What if you can't? (Xserver compile bug, long offline professional corporate support delays)
long live PCem
Debian's fucked
Reply 8 of 13, by wd
Rank DOSBox Author
DOSBox Author
Bad luck then, use dosemu.
Reply 9 of 13, by jcdutton
I want this because I have a DOS program that only used text mode. I am currently running it remotely over an X session, but it uses a lot of bandwidth on the network. dosemu is not able to run this application for some unknown reason.
If dosbox could instead only send the text chars from the text mode, much less bandwidth could be used. I know that when a VGA card is run in text mode, the characters are stored in video memory as chars, and not bitmaps.
Reply 10 of 13, by wd
Rank DOSBox Author
DOSBox Author
Then you need to program that.
Reply 11 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
ctty comes to mind
1+1=10
Reply 12 of 13, by MiniMax
Rank Moderator
Moderator
Ahh!!! FINALLY valid reason for wanting to use text-mode only instead of "It would be cool!!!"
I am not up to date on how well X-traffic is normally compressed, but check if you have an option somewhere in the X-server for compression.
If not, try running your X-session over an SSH-tunnel with compression enabled in SSH.
Or, try VNC. VNC might be more effective when it comes to screen updates.
_________________
Reply 13 of 13, by ninjalj
You can try nx for X compression. Also, there's always ssh -X -C, which does deflate compression, IIRC
