First post, by cogs
i have 'chasm: the rift', and using 'dfend reloaded'
gfx: voodoo3
ram: 256
what i wanted, was someone's settings for chasm that makes the game look its best and run its fastest. i don't know what this type of file is called, but something to change my config file (it doesn't have to be through dfr, unless you want, because i can change the dosbox config file). ps,if you have to use mouse2kv.exe, please give those settings as well? thank you! cogs - new to dosbox
