First post, by TheArkive
- Newbie
EDIT: Works just fine on Vista x64. CubanRaul also updated his patch to v2.0, making the uploads on this post obsolete.
EDIT: UPDATED v3
First off, here's my specs so you know what I was working with.
AMD Athlon 64 X2 Dual Core 3800+ (FSB 200 Mhz) KN8 SLI (NF-CK804) .... nForce4 chipset 2048 MB DDR Dual Channel (PC3200 - 400 MH […]
2048 MB DDR Dual Channel (PC3200 - 400 MHz Max)
Plextor DVDR PX-750A
nVidia GeForce 9800 GTX+ 1GB
Realtek AC'97
Windows XP Pro SP3
Here's the latest:
CubanRaul has released a v1.4 to his patch that includes automatic cpu slow-down.
CubanRaul's Page: http://home.comcast.net/~heavyweights/games/kain/index.htm
This will run CPU Grabber in the background. I think he modified it to actually work with Dual Core systems. This patch works beautifully.
If you don't want to run a CPU slow-down utility in the background there's another patch out there. You will need CubanRaul's v1.2 patch, and BO1Fix.exe patch made by VampMaster (additional credits go to Wrace).
Forum Link: http://forums.eidosgames.com/showthread.php?t=72756
All patches are included below. Make sure to use the correct combinations!
