Supaplex odd behavior
First post, by milicognj
I have experienced very odd behaviour of dosbox when running Supaplex.
If I start the game through conf file the game screen freezes just after the chosen level is started.
Then I have edited the conf file and only deleted the last line that starts the game.
After this everything was normal.
This is pretty odd. What it could be?
Ognjen Milic
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
try for the sake of testing starting the game using a bat file.
see if that makes a difference
Water flows down the stream
Reply 2 of 4, by milicognj
Hi,
I made su.bat that only calls supaplex.exe and the game works normaly.
Ognjen Milic
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
very odd. I'm not sure what would be causing it. autoexec.bat isn't that different from a regular bat file.
Reply 4 of 4, by milicognj
Here are the lines of autoexec.bat from the conf file.
When I remove the last line and call exe or bat file everything works normaly.
I downloaded the last cvs build today (06.09.2008) and the situation is same.
mount C "c:\" -ioctl
mount A "C:\Igre\logicke\SUPAPLEX\r" -t floppy
C:
cd \Igre\logicke\SUPAPLEX
SUPAPLEX.EXE
