First post, by redbear
Hi i am trying to setup Janes Longbow the original one not the gold ok.
It runs the itro screen and the vidios within the game really fine but when i load up a mission i get a bad colored graphics on it here is a picture of it
I have tryed Open gl, direct draw i am runnig in vga machine and i am setting up the config file in dosbox with D.O.G i have tryed every thing to no avail here is a copy of the setup file i am using
[sdl]
fullscreen=true
fulldouble=false
fullresolution=640x480
windowresolution=640x480
output=openglnb
autolock=true
sensitivity=100
waitonerror=true
priority=normal,lower
mapperfile=
usescancodes=true
[dosbox]
language=
machine=vga
captures=d:\janes\longbow\
memsize=63
[render]
frameskip=10
aspect=true
scaler=none
[cpu]
core=auto
cycles=9000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=
[speaker]
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
joysticktype=fcs
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=disabled
serial2=disabled
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
ipx=false
[autoexec]
mount c "d:\janes\longbow"
mount d "g:\" -t cdrom -label JLBCD107F_1
mount y "f:\documents and settings\isaac antequera\escritorio\dog-153\plugins"
Y:
cd/
cd cwsdpmi\bin
CWSDPMI.exe -p -sY:\cwsdpmi\bin\cwsdpmi.swp
C:
cd/
LB.EXE
exit
I also use some setting from a post here in a cofiguration of a longbow gold but nothing works.
Jane's Longbow Gold on WinXP - thank YOU DosBox!
so if you have any recomendations please let me know if i have to download a driver or something.
My system cofiguration
AMD +3800 dual 2Gb ram Nvidia 8500 drivers 177.92 beta the video card has 512 mb ram Win XP SP3 the DOSbox vertion i am using is the 0.72.
the installation of longbow is comple with the flash point Korea add on.
Thanks in advance.
