First post, by patrikup
Motherboard: Notebook Compaq nx6310
Processor type and speed: Celeron M 1,46 Ghz
Amount and type of RAM: 1Gb
Video board w/ RAM amount and type : 8Mb
Sound board: default
Operating system: Win Xp
Game name (and version, if applicable) : Elite (1987)
Description of problem: The game is playable but, under every Dosbox version don't load and check the list of the saved game file.
However the game save and load if runned by prompt without dosbox.
Reproducibility of problem: Always if you run it under Dosbox.
Sound mode used: Default
Video mode: Default
Version of emulator: all dosbox version
Steps already attempted to solve the problem : nothing
To understand and reach the problem, run the game under dosbox, pres ESC anytime you want douring your orbital station permanence.
Now you are in the game control pannel where you can save, load, check the list of the save game, set the control and exit to DOS.
If you save the game, you can see the saved game file in the windows folder but the game don't list the file using the check command "C" and don't reload the saved game file using the "L" load command.
The same procedure, without dosbox, run but the playability is imposible by the clock normal overframing.
Reply 1 of 26, by MiniMax
Rank Moderator
Moderator
You are not alone:
http://www.dosbox.com/comp_list.php?showID=49 … =E&search=Elite
Does it help if you press CTRL-F4 (which tells DOSBox to refresh the drive cache)?
_________________
Reply 2 of 26, by patrikup
eheheh... too much easy.
Ctrl F4 doesn't work for this issue.
So I think that is a "variable" problem. Infact if you save the game without dosbox running, but in the same status, if you go in the windows folder, open the saved file with notepad, save without changing anyting, and return to the game (without dosbox running), the file doesn't work.
Then, I think there is something that if the saved game file (.CDR extention) was modyfied by another program (DosBox also), doesn't work.
I think that when the game program hand to the dosbox the seved game file, dosbox change someting and the file lost its authenticity.
Really, I don't know how can I solve di problem. 😢
Reply 4 of 26, by MiniMax
Rank Moderator
Moderator
Please try this:
1) Start DOSBox.
2) Start Elite.
3) Go to the game control panel.
4) Save the game position.
5) Exit game.
6) Exit DOSBox.
7) Start DOSBox.
8) Start Elite.
9) Go to the game control panel.
10) Do the saved game position show up?
11) Can you load the saved game position?
12) Does it work?
_________________
Reply 5 of 26, by patrikup
sure!
I post the url, becouse I don't want to zip o rename the extention.
Game file: Game
saved game file that work: WORK.CDR
saved game file that not work: NORK.CDR
Note: I think that the control pannel doesn't case sensitive, but I've try both case and work also.
I'm patient waiting for your response.
Thank you...
Please try this: […]
Please try this:
1) Start DOSBox.
2) Start Elite.
5) Exit game.
6) Exit DOSBox.
7) Start DOSBox.
😎 Start Elite.
12) Does it work?
Sorry Minimax but doesn't work. It doesn't also in the same dosbox session.
Maybe if Chrisintx don't remember how he fix the problem or somelse find the key, I'm really going crazy.... 😒
Reply 6 of 26, by MiniMax
Rank Moderator
Moderator
Those URL's doesn't work for me. They lead me straight to the front-page: http://it.altervista.org/
_________________
Reply 7 of 26, by wd
Rank DOSBox Author
DOSBox Author
Please download the WORK.CDR file you uploaded (be sure you put it into an
empty directory), then copy the game files into that directory (excluding all
savegame-related files), and see if it works.
If it doesn't it has to do with file attributes as noted on the dosbox compatibility page.
Reply 8 of 26, by patrikup
@MiniMax : You have to right click mouse and save like object. 😎 if you open like a web page the host redirect you to the root host page. 🤑
Please download the WORK.CDR file you uploaded (be sure you put it into an empty directory), then copy the game files into that […]
I've do that yet. Both the game file and the saved game file was in a empty folder
C:\elite\elite.exe
and
C:\elite\WORK.CDR
Have you the same issue? Did you try it? Waht happen?
Reply 9 of 26, by MiniMax
Rank Moderator
Moderator
Both files looks okay to me. Same size, same structure, no CR/LF conversions:
$ vd WORK.CDR
0: 43 6F 6D 6D 61 6E 64 65 72 20 66 69 6C 65 1A 0F | Commander file..
10: 0D 43 4F 4D 4D 41 4E 44 45 52 20 00 20 20 20 20 | .COMMANDER .
20: 20 20 31 39 37 2E 35 20 43 72 65 64 69 74 73 00 | 197.5 Credits.
30: 4A 5A 48 02 53 B7 00 14 56 50 40 50 40 14 56 01 | JZH.S...VP@P@.V.
40: 4C 41 56 45 00 00 00 00 00 04 07 00 00 03 02 05 | LAVE............
50: 1C FF 00 00 00 F0 34 84 18 4C 41 56 45 20 20 20 | ......4..LAVE
60: 20 00 04 07 00 00 03 02 05 1C FF 00 00 00 F0 34 | ..............4
70: 84 18 A4 B9 B9 AC 00 FF 00 00 00 01 00 00 00 00 | ................
80: 00 00 00 00 00 00 01 00 B7 07 00 00 00 00 00 4A | ...............J
90: 41 4D 45 53 4F 4E 20 00 00 00 00 00 00 00 00 00 | AMESON .........
A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
D0: 00 | .
$ vd NORK.CDR
20: 20 20 35 30 33 2E 34 20 43 72 65 64 69 74 73 00 | 503.4 Credits.
70: 84 18 A4 B9 B9 AC 00 FF 03 00 00 00 00 00 00 00 | ................
80: 00 00 00 00 00 00 00 00 AA 13 00 00 00 00 00 4A | ...............J
D0: 00 | .
Commander Jameson is obvious docked at space station Lave 😀
_________________
Reply 10 of 26, by patrikup
Maybe the .Exe track the created time of the saved game files? 😕
So, maybe during the passage Elite.exe==>DosBox==>Folder the file is created with a time delay? 😦
or the exe track the file including a train of bit in the saved game file.
Becouse if you modify by the Ex-editor the cash the saved game file don't work also. Eheheheh! 🤑
I'm beginnig to be paranoid.... maybe the FBI and the NASA don't want to discover the secrets of this game.... 😁
maybe alien exist 😁
maybe I'm alien 😁
maybe.... 😁
Dam! I wanna play Elite!!!! 🤣
Reply 11 of 26, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The problem is indeed the file attributes. The game clears all file attributes on the file when it creates it, and then expects all attributes to be clear when it loads it. DOSBox indicates the archive flag is set, even if it's cleared in the WinXP file system, and the game thinks this is an error condition for some reason.
I adapted another file attribute fix I've made before; this one will report no attributes for any file with a ".CDR" extension while the TSR is loaded. Source code is included.
    ELFIX.ZIP
    973 Bytes
    2116 downloads
Reply 12 of 26, by patrikup
Mmmm.... really I don't understand what you said! 🤣
Where I have to put your uploaded file?In the game folder? I have to run it every time that I use dosbox to clear the saved file attribute? I run before e during the dosbox running, I run it before and after I save the game... but... don't work. I'm sure I doing someting wrong. Have you a Elfix.exe user manual for newbe? 😅
Some one can explain me how I can see the file attribute? I need a exeditor?
Reply 13 of 26, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Doesn't matter where you put it, but for simplicity just put it in the same folder as the game. It does not change attributes on files, it alters how they are reported through a DOS call.
Make sure you are running the fix inside DOSBox before you run ELITE.EXE, then the game should load saved games without the error.
Reply 14 of 26, by MiniMax
Rank Moderator
Moderator
A littel detective work by yours truely reveals the same - the Archive flag is set when the CDR file is created. But it works for me if I do an
ATTRIB -A *.CDR
from the Windows CMD-console before launching Elite.
_________________
Reply 15 of 26, by MiniMax
Rank Moderator
Moderator
You have to run it inside DOSBox just before you run Elite:
C:\> ELFIX
C:\> ELITE
No, right-click on the file, and choose Properties. You should see the 3 attributes:
[ ] Write protected [ ] Hidden [X] Archive
The Archive-attribute needs to be cleared for ELITE to recognize the file correctly. ripsaw800's little program tricks ELITE into thinking that the Archive attribute is clear no matter what.
I made a little BAT-file (with Notepad) called RUN.BAT that loads & run it all:
@echo Loading ELFIX, an TSR by ripsaw800. Fixes a problem with file attributes.
@ELFIX.COM
@echo Loading ELITE
@ELITE.EXE
Now all I have to do is to write RUN in DOSBox 😀
Now that you know all this, you should probably ditch Elite and instead use Elite Plus 😀 Much better sound and graphics in Elite Plus.
_________________
Reply 16 of 26, by ripsaw8080
Rank DOSBox Author
DOSBox Author
That's strange... even when I clear the archive flag in WinXP, DOSBox still indicates it is set through INT 21/4300. Why would it be different for someone else?
Edit: I answered my own question. Apparently it is different when a FAT volume is in use (drive_fat.cpp vs. drive_local.cpp). The source code appears to default to just the archive flag for all files for drive_local.cpp
Reply 17 of 26, by MiniMax
Rank Moderator
Moderator
Or - I made a mistake. I can't get it to work now, even when I run it from my USB-stick with a FAT-filesystem.
I probably ran ELITE directly from the CMD-prompt after I had cleared the A-bit.
_________________
Reply 18 of 26, by patrikup
Minimax and Ripsaw8080.... I love you! 🤣
Good job men!
Elite run, save and load.
Wow really I never seen a software problem solving faster than you... 😁
About the Flag I have the same problem... Maybe if you delete the flag you have to reboot? I don't know... 😕
However... at the last all gonna better! eheheh! Thank you very much!
You save I little student that can play only Elite between a medicine exam and boring lesson at the university. Thank you!
P.S. I dont like Elite plus so much.... I love my old 4 color graphic! eheheh! When I start to play computer at 6 year old I begin with a PC1 Olivetti Prodest (no HD only SDFloppy Drive 4 color and Ram 512KB).
Reply 19 of 26, by GalaxyHigh
I know this is a very, very late response but has anyone had issues running this uner Win 7?
I'm running DosBox 0.73 and have tried running the bat patch and manually adding attrib -a *.cmd
I notice that Win 7 doesn't archive files in the same way XP does. Could this be an issue?
Regards.
EDIT: My apologies, DosBox 0.74
Win 7 Ultimate 32
1x2GB RAM
2.7GHz AMD 64 x2 5200+
GeForce 9500GT+
1x2TB SATA
1x500GB IDE
