First post, by hizzout
For some reason in this game I cannot run in a diagonal direction.
The mappings for this game are for P1 to use the keypad, as in UDLR = 8246
The players will only run in the 4 cardinal directions, and not diagonally. If I press the diagonal keys on the keypad (7913) they will run diagonally, but not if I do a combined press of say buttons 8 and 6 to run to the upper right.
I've tried with both NUMLOCK on and off with the same result.
I tried the mapper (CTRL+F1) and mapped the 8246 keys to the arrow keys, but that also will not allow them to run diagonally.
Can anyone assist?
Thanks in advance
Reply 1 of 3, by sam767
Try hitting Num lock key Several times and then back and forth between arrows and keypads , this trick work with Ancient Empires but i dunno if its only AE case
Reply 2 of 3, by hizzout
Nope that doesn't work. 🙁
Reply 3 of 3, by hizzout
Sorry to bump this, but I'm still having this issue if anyone knows a way around it please let me know!
Thanks,
