USB/serial converters with dosbox
General information and assistance with DOSBox.
Postby joeb4print » 2008-10-04 @ 06:01
I have a PC running Vista that has no serial ports. So I purchased a USB TO SERIAL DB25 Adapter (22429) from CablesToGo. In the Dos Box config file I need to enter a value for Serial1 in the form of:
serial1=directserial realport:????
I assume I need to enter the USB port number instead of a Com number since there are no physical com ports on this PC. Where can I find out what that USB port designation is?
In Device Manager for the adapter it shows:
I've tried entering that but still had no luck.
Any help would be greatly appreciated. I hope this isn't a redundent topic as I've done quite a bit of searching and could not find an answer.
Thanks.
joeb4print
Re: USB/serial converters with dosbox
Postby Harekiet » 2008-10-04 @ 07:25
Open a command prompt window and type
wmic /namespace:\\root\cimv2 PATH Win32_SerialPort GET caption,description,deviceid
That should give you a list of com ports and the deviceid is the name you'd be interested in for using in the dosbox config.
User avatar
Harekiet
DOSBox Author
Postby joeb4print » 2008-10-04 @ 09:17
Thanks for the reply.
I'm not at that work computer now but I brought the cable home to try on my PC at home. It's running XP and does have physical serial ports, Com1 & Com2. I installed the drive for the USB to Serial cable and it lists it in Windows Device Manager as being Com3. When trying your suggestion it only comes back with information for Com1 & Com2. Nothing about Com3 at all. Any ideas?
joeb4print
Postby h-a-l-9000 » 2008-10-04 @ 10:02
Does Vista have a device manager? Doesn't it show the com port number?
1+1=10
h-a-l-9000
DOSBox Author
Postby joeb4print » 2008-10-04 @ 15:43
Yes, it shows the com port number as Com1 but it doesn't work when I enter in:
serial1=directserial realport:Com1
no errors or anything but it just doesn't work in the DOS application. It's time clock software. It's name is OES-Plus III. Can't find out much info on it. It has been running on Mac OS 9.2 running PC (DOS) emulation software
I've brought the cable home for the weekend and I'm trying to get it working on my XP machine using an old fax/modem. Basically just wanting to make sure it's possible to use the serial to USB cable with Dos Box. On it I enter modem instead of directserial and when I launch DOS Box the status window says "Serial3: Modem listening on Port 23..." Would that mean that it is working on the XP machine?
joeb4print
Postby h-a-l-9000 » 2008-10-04 @ 16:31
serialx=modem has nothing to do with a real modem.
Try with a real (non-USB) serial port, could be it works then. Certain USB/serial cables have driver incompatibilities. If it still doesn't work try a CVS build or the one from my homepage, there have been some improvements since 0.72.
There is also a chance it won't work at all...
1+1=10
h-a-l-9000
DOSBox Author
Postby joeb4print » 2008-10-04 @ 17:40
Like I said, the Vista machine does not have real serial ports. Just testing on the home XP machine that does. I really need the USB to serial cable to work on the Vista machine.
So even though I'm using a USB to serial cable hooked to a modem the setting should use directserial instead of modem? If that is the case it brings me back to my original question of how to found out the USB port number and how to enter it exactly in the config file or even if that will work? And am I right in thinking that although device manager says it's on Com1 that is NOT the realport that I would enter into the config file?
I will try it on the real com port on my XP machine because I suppose I could buy a serial PCI card and put it in the PC to add the real serial ports. I spent $40 on this cable though so if at all possible I'd like to be able to use it.
joeb4print
Postby h-a-l-9000 » 2008-10-04 @ 18:04
The comX from the device manager is the correct one to use. The status window should say "Opening comX..."
yes.
When you have the modem connected run some terminal software in DOSBox and type i.e. 'ATZ', it should return 'OK'.
1+1=10
h-a-l-9000
DOSBox Author
Postby joeb4print » 2008-10-05 @ 06:04
Thanks, it seems to be working fine on my XP machine. I get the OK after entering ATZ. At least now I know the cable works with DosBox. I'll try the same tests on the Vista machine next week. I have a feeling it's the time clock software program that doesn't want to play along with everything else.
joeb4print
Postby joeb4print » 2008-10-08 @ 09:07
Thanks to h-a-l-9000 and Harekiet for your help. I have it working. In the config file I had entered:
"serial1=directserial realport:com1"
and was having no luck getting it to work with the time clock it was connected to through a modem. I had set up the USB/Serial converter in Vista to com1 as:
Bits per second: 9600
Data bits: 8
Parity: None
Stop bits: 2
which matched the settings on the com port from the old Mac and the settings in the timeclock software. I assumed since I set the com port up in Windows with those settings that it would use them. I know, never assume, and once again it came back to haunt me. The solution was to change the config file to:
serial1=directserial realport:com1 startbps:9600 parity:n bytesize:8 stopbits:2
It all worked perfectly after that.
Thanks again. Great software.
joeb4print
Postby h-a-l-9000 » 2008-10-08 @ 09:42
Um, these values aren't evaluated.
1+1=10
h-a-l-9000
DOSBox Author
Postby joeb4print » 2008-10-08 @ 23:16
Huh? It does not work without them and does work with them.
joeb4print
Postby h-a-l-9000 » 2008-10-08 @ 23:24
Then you are using something older than DOSBox 0.72.
In 0.72 you can use the FreeDOS mode.com file to change the com port parameters.
1+1=10
h-a-l-9000
DOSBox Author
Postby joeb4print » 2008-10-09 @ 02:54
Well, after you posted that those values were not evaluated, I went back and removed them it is still working okay. So the line I have now is:
I know I tried that last week and it would not work for anything. And now it is.
joeb4print
Postby wd » 2008-10-09 @ 06:19
I can second that. What did you do during that week?
wd
DOSBox Author
Postby MiniMax » 2008-10-09 @ 08:10
What did you drink (or smoke)?
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
User avatar
MiniMax
Moderator
Location: Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 0 guests
