Mouse problem
First post, by speedy55555
Hi, I am a newbie to this form so I didn't quite know where to put this. 😀
But, well, to the problem: for the game called Indy Car Racing Two and it's made from Sierra. I need to know how uninstall the driver for the mouse and the control config is always thinking I'm moving the mouse to the left. 😕 Could somebody tell me how to disable the mouse or or uninstall it's driver? 😖
Reply 3 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The attached program will completely disable the mouse if you run it inside DOSBox before running anything else. Note that it is not fancy, and does not provide a way to re-enable the mouse other than to restart DOSBox. At least you'll be able to determine if the mouse is the cause of your problem.
    mouseoff.zip
    152 Bytes
    1845 downloads
Reply 6 of 6, by coolhaken
Run the executable of a mouse driver will "turn on" the mouse.
So I think "mouseon" is not needed at all.
You may want to try the mouse driver I attached.
Some CGA games run in Hercules mode with SIMCGA(HGC(Hercules, Monochrome) support still not perfect) can't detect the mouse driver that DOSBox built in.
For example, "Shadow Gate" and "PT-109".
This driver solves the problem.
Note: "imouse /h" shows the help message.
    IMOUSE.zip
    8.53 KiB
    401 downloads
