KQ7 restype.cpp(54)
First post, by Millencolin
When i run KQ7 using DOSBox i keep running in to an error.
Error 99: Error loading resource 1304.wav
..\restype.ccp(54)
Anyone know how to fix this?
Reply 1 of 8, by eL_PuSHeR
Read the posting guidelines, faqs, readmes, etc...
Your question is too vague.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 8, by Millencolin
Ok, to be more specific.
I started KQ7 using DOSBox.
During the intro i got the following error:
..\resttype.cpp(54)
Script 1250/S6a3
I can't be more specific.
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Oh you could be WAY more specific, especially regarding what dosbox version
you are using, the OS, how you installed the game etc.
Reply 5 of 8, by Millencolin
I mounted the drive this way:
Z:\MOUNT C C: /
I put the game in a specific folder called OLDgames\KQ7
After that i could open the game using sierra.exe
I'm using Windows Vista.
DOSbox version 0.72
During the intro it just stops running and showing this specific error.
Someone said i should create a blank .wav but that didn't work out.
Reply 6 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
to ask again: how did you install the game? If your mounts you did during installation and playing the game do not match you can run into such a problem.
Reply 8 of 8, by IIGS_User
I assume he installed it using Windows and then tried DOSBox to run it instead of installing it within DOSBox after doing his mounts.
Please mount "Oldgames" as C: and then install the game (within DOSBox) into "Oldgames/Sierra/KQ7", in DOSBox seen as "Sierra/KQ7".
Klimawandel.
