First post, by z9d10
z9d10
Offline
- Member
hey paul I came across the wikipedia entry for Glidos . it was a bit sparse ( and has been tagged as an orphan 🙁
At any rate I added a bit to it ( and got some references and links ) so hopefully it doesn't get deleted . I was wondering if I could have permission to use some of the images from your site for the wiki page , and if you would give it the once over to suggest any additions or changes .
( I seem to remember you saying that the fellow whom got you a certain dos compiler enabled the project, but I can't remember the specifics 😀
also if there are any Glidos review links you know of still floating around I would like to add them
thanks again -Rild
