First post, by RayzaII
I have managed to get this game going under dosbox and enabled multiplayer button but cant see my other machine running fragile on the internet I am guessing it is because of NAT settings and port forwarding setup.
Does anyone know what ports Fragile uses in IPX or do I use dosbox ports?
Anyone help please
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
1) The IPX thing in DOSBox only works with other DOSBox'es.
2) You decide what port to use for the IPX server in DOSBox.
_________________
Reply 2 of 2, by RayzaII
Thanks buddy it took some time to figure it out but got there in the end.
