First post, by Moogle!
Before I blow 37USD, I need to know if it will work.
I got a 486 board from 1992. It's an Alaris Leopard rev C. It's BIOS date is 6-6-92. I know there is a later one, (11-11-92, and possibly one later than that), but I cannot find them.
I am using the aforementioned Alaris board. IBM SLC2, 66Mhz, 16MB Ram. I am using a DOS 6.22 bootdisk, the same one as I used while building my 486 tower of Power (where I did not have this issue, BIOS is from 94). I have two different 1GB hard drivers, and a Holtek 6560B VLB Enhanced IDE controller. In the BIOS, it reads both the correct size for both of the drives, but I cannot get FDISK to make a partition bigger than 504MB. I have tried the card with and without drivers. (it won't even load Fdisk with the drivers, for either drive, and I tried two different versions of the drivers), from what I understand, this is a mainboard BIOS issue, where most board made before a certain time will not do more than 504MB.
So, I've decided to go the SCSI route. I'm looking at an Adaptec 2842VL controller. And if I'm understanding correctly, the SCSI controller will not be limited by the motherbords bios. Am I correct? I did not have any issues with this on my EISA SCSI Compaq Deskpro, either, and it had a BIOS from 92, also.
Reply 1 of 8, by Amigaz
I think the drive size limit is 8gig but I might be wrong
Csn't see any drive size limits i it's specs at adaptec.com
My Adaptec EISA 2742AT and PCI 2940UW have an 8gig limit
But the 8gig is no problems since you cvan use a bigger hd but only 8gig will be usable on the drive
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 2 of 8, by dvwjr
I believe that all non-Windows DOS (ie <= v6.22) are the limiting factors in drive size when used with a SCSI controller and SCSI drive combination. The 2940UW int13h extensions would allow a Win9x DOS 7.x to address larger than 8GB FAT32x formatted SCSI drives on an older 486 system with VLB or PCI.
For the PCI 2940uw PCI Adaptec SCSI adapter the highest released FLASH BIOS update was the hard to find version 3.10, which had a fix to display SCSI drives larger than 60GB. I believe that the older SCSI LBA drive size limit is 2.2TB with 32-bit operating systems.
Attached is the Adaptec 2940uw v3.10 BIOS update package.
Note: this is not the Adaptec 2940u2w SCSI host adapter BIOS update package which has been posted below.
dvwjr
edit: fixed text and included info on below 2940u2w post.
    2940uw_bios_3100.zip
    276.37 KiB
    581 downloads
    Adaptec 2940UW (only) BIOS update v3.10 package.
Reply 4 of 8, by dvwjr
Just for completeness sake: 😁
For the PCI 2940u2w PCI Adaptec SCSI adapter the highest released FLASH BIOS update was also the hard to find version 3.10, which had a fix to display SCSI drives larger than 60GB. I believe that the older SCSI LBA drive size limit is 2.2TB with 32-bit operating systems.
Attached is the Adaptec 2940u2w v3.10 BIOS update package.
Note: this is not the Adaptec 2940uw PCI SCSI host adapter BIOS update package which is posted in an above message.
dvwjr
    2940u2w_bios_3100.zip
    276.37 KiB
    699 downloads
    Adaptec 2940u2w (only) BIOS update v3.10 package.
Reply 5 of 8, by Amigaz
dvwjr wrote:
I believe that all non-Windows DOS (ie <= v6.22) are the limiting factors in drive size when used with a SCSI controller and SCS […]
dvwjr
Mine is the AHA 2940UW PRO, not sure if this BIOS works with my card...
I tested it yesterday...the BIOS version is 2.11 and at least it can see the full 18gig of my harddrive I tested with it.
Reply 6 of 8, by samudra
No need to blow $37 on a Adaptec 2842VL.
That is way too much money. You should be able to get one for $5 or less.
I'd recommend you look at the 2840A instead. It is newest of all the Adaptec VLB SCSI adaptors and is compatible with L1 WB cache.
This is not a QEMM error.
Reply 7 of 8, by Moogle!
It was actually 26.90, and it had a floppy controller on it, which I would have needed, as I don't have any working I/O controllers with a floppy. I also got a 1.05GB hdd for it. I could have spent less, but I wanted an Adaptec controller.
I also picked up a 2940 PCI controller for the Tower of Power, and a 2.1GB disk for it.
Reply 8 of 8, by samudra
You could have spent less and still got the Adaptec.
But hey, you probably got one brand new and sealed in the original box for that price which is good.
