First post, by Zephyr
So, I've been trying to get SSI's Fantasy General to work under Windows 2000 for some time now, with little success. I've managed to get it working with VDMSound so that the sounds actually work, but because of the mouse problem, I can't get past the initial menu screen. It's the infamous 'stuck in the upper left corner' symptom. MOUSECTL helped a bit; I could move the mouse a bit further, but it was always pulled back to the corner. Fantasy General crashes when ran through MOUSE2KV, which in turn is run through VDMSound. The output for the error is below, I hope someone could tell what I'm doing wrong.
The options for Mouse2KV are 640 480 8 8.
MOUSE2KV v.1
Win2k/NTVDM/VESA/Mouse utility by Peter Maceluch
Designed to address the issues with mouse cursor being unable
to reach whole screen in some DOS programs in Win2k
Special thanks to Vlad ROMASCANU for MOUSESET sources this program
was based on.
DOS/4GW Professional Protected Mode Run-time Version 1.96
Copyright (c) Rational Systems, Inc. 1990-1994
DOS/4GW Professional error (2001): exception 0Dh (general protection fault) at 3
07:0000000B
TSF32: prev_tsf32 69FC
SS 30F DS 30F ES 30F FS 0 GS 17F
EAX 2867044 EBX 2866DF4 ECX 0 EDX 0
ESI 284014D EDI 2866E03 EBP 2879A94 ESP 2879A7C
CS:IP 307:0000000B ID 0D COD 0 FLG 13246
CS= 307, USE32, page granular, limit 7FFEFFFF, base 0, acc C7FB
SS= 30F, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
DS= 30F, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
ES= 30F, USE32, page granular, limit 7FFEFFFF, base 0, acc C7F3
FS= 0, USE16, byte granular, limit 0, base 0, acc 0
GS= 17F, USE16, byte granular, limit FFFF, base 169F0, acc F3
CR0: unavailable
