First post, by retro games 100
- l33t
Mobo is "empty", except for a brand new PCI ATI Rage 128 Pro.
Format HDD - OK
Install Windows 98SE - OK
Install chipset drivers - OK
So far, so good. VGA image looks good.
I try to install the ATI drivers (either downloaded from ATI website, or from the ATI install disc) - no joy. Error message =
"This display driver is not compatible with the display adapter(s) installed in your system."
(Earlier, I tested an identical 2nd graphics card in the same mobo - no problems.)
The "broken" card looks fine, but I think it may be damaged somehow.
However, testing a VESA 800x600 DOS game worked fine, so maybe I can still use it, just not for Windows.
Strange. 😖
