First post, by Linos
Hello, i have some problems with the game "Pizza Connection".
I can play it with dosbox 0.72 for a while, but when my first restaurant is full with people and some time is ago and i want to create a new pizza, the game stucks and need to close it ...
When i click for example on cheese or another thing ... Dosbox said
Illegal read from 30301ce, CS:IP 150: 16f356
This sentence comes 100times and game freezed......
Plz help me , i allready tried something with the cpu cycles and troubleshooting from dosbox readme... but still nothing works ...
Reply 1 of 14, by wd
Rank DOSBox Author
DOSBox Author
Be sure sound is configured correctly (ie. matches your dosbox.conf settings),
and see if it works better with core=normal
Reply 2 of 14, by Linos
This are my settings which i have changed.... on another pc i tried with the default settings...but the same problems as mine
core=normal
cycles=10000
cycleup=500
cycledown=20
nosound=true
rate=22050
blocksize=2048
prebuffer=10
sbtype=none
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
pcspeaker=none
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
xms=false
ems=false
umb=true
keyboardlayout=none
Reply 3 of 14, by wd
Rank DOSBox Author
DOSBox Author
How did you install it, how does your mounting like when starting the game,
and how exactly do you start it?
Reply 4 of 14, by Linos
i used this file to install dosbox DOSBox0.72-win32-installer.exe
i started dosbox with the desktoop shortcut and then:
mount c c:\pizza (enter)
pizza (enter)
then he makes
c:\sound\sound.com
creative sound blaster fm-driver version 1.34
bla bla bla
Error 0006: Blaster variable not avaible
c:\pc
Dos/4GW protected mode run-time version 1.95
bla bla
or what u want to know?
Reply 5 of 14, by wd
Rank DOSBox Author
DOSBox Author
Well looks like it's not correctly installed. Anyways you can try to put the pizza
subdirectory into another directory, for example c:\oldgames. So you'll get a
c:\oldgames\pizza dir, then you can do a "mount c c:\oldgames" which should
be closer to the real thing.
Reply 6 of 14, by Linos
Its the same ...when i changed the folders... same problem 🙁.
i have downloaded the pizza game from nostalgiegames or something like that. I dont found another version on the net.
Or do you mean my dosbox is not correct installed? I did it on 2 pcs and both have the same problem ...i have read here in the forum someone other have the same problem but i found no help
OSX, Pizza Tycoon and olives...
Reply 7 of 14, by wd
Rank DOSBox Author
DOSBox Author
Yeh dunno, ask those guys where you downloaded it. Afaik this game is still
copyrighted so it's illegal to download it.
Reply 8 of 14, by Linos
Hmm i think i saw it as freeware....you think when i have the original version it will work?
i dont want to try it out when its not working then ... 🙁
Reply 10 of 14, by wd
Rank DOSBox Author
DOSBox Author
Uhm no idea unless somebody tries it.
Reply 11 of 14, by lightmaster
maybe it should be installed in \ (root)
Reply 12 of 14, by eL_PuSHeR
I think your mounting is bad.
mount c c:\oldgames\pizza
Create a c:\oldgames and mount it as C
then
cd pizza
pizza
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 13 of 14, by Linos
its still the same problem ...
i dont know why i can create the diffrents pizza at the start of the game but not anymore during the game....
i tried diffrent settings but nothing helps me :\
Reply 14 of 14, by Linos
Aftetr some time playing ...its seems thats no crashing till now...
hmmm weird... i can create new pizza and no illegal reads... entering the restaurant no illegal reads...
maybe i need to get over a specified date in game
