First post, by retro games 100
- l33t
I've got it attached to a Turtle Beach Santa Cruz PCI card, running in Windows 98SE, using santa cruz VxD drivers.
I try the MS directx testing app called "dxdiag", and in the Music tab section, I select the "santa cruz external midi" for testing. I listen to the tune, and it sounds weird, like some of the instruments are not the correctly chosen ones for the song. Something isn't right.
Inside windows Control Panel, and inside the "Multimedia" app, I select the Midi tab, and select "santa cruz external midi" as the single instrument midi output. I then listen to a midi song inside "windows media player" and it sounds better, but unfortunately I just don't trust windows, and therefore I cannot say for certain if it is really using the daughterboard.
What is a trustworthy piece of software that I can use inside windows 98SE, that I can select the daughterboard for midi output, and really know for sure that it is the db that is being used when playing midi songs?
Thanks very much, I appreciate it. 😀
