First post, by Scrogz
Please bear with me as I am fairly new to using DosBox.
I am using the DBGL JAVA front end for DosBox as I have totally failed at running DosBox without some sort of front end. Using this front end DoxBox is working fine but I am trying to make a change that I am not sure is possible.
I am sorry but I am at work 😊 and do not have my DosBox version handy but I have the latest version of DBGL installed.
When playing Railroad Tycoon I would like to slow the game up as much as possible. The best experience playing Railroad Tycoon is on an 8088 Processor. As you use a fast processor game time will move much faster but your trains do not speed up at the same rate.
For example, on an 8088 machine I might get 10 deliveries in a month. On a 386 machine I might only get 5. On a 486 machine I might only get 3.
This tends to throw the economics of the game off a bit.
I am looking for a way to "slow the game up" either in my Front End or DosBox itself. I'd like to emulate as slow a processor as possible.
Is this something I can do in DosBox? If so, can someone either direct me to a place the explains how to do this or provide me with an explanation on how to make this happen?
Thanks in advance for your help!!
